Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 10-08-2013, 07:14 PM   #1
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
ls7 camaro vs blown 5.0
I'm nearly finished with my build and it consists of a ls7 long block with PRC 285 heads a 11.45 SCR a 24x/25x 6xx/6xx cam full boltons and 1le gears. My friend has a 2013 5.0 with a TVs s/c on 7psi and full Bolton's both of these cars will be running street tires for the first time to the drag strip just for shits and laughs and second encounter will be on drag radials. Who do you guys think will take the W.
Nightmare2012 is offline   Reply With Quote
Old 10-08-2013, 07:21 PM   #2
JEFF75645
Drives: his wife crazy buying mods
Come on man. Whxt dx txe x's mxan?
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 10-08-2013, 07:25 PM   #3
CobraBall
Drives: Blue
Some power output numbers would help too. Most of us have no idea what either combination puts out.
CobraBall is offline   Reply With Quote
Old 10-08-2013, 08:57 PM   #4
camaro-dreamer
camaro-dreamer's Avatar
Drives: 2013 Porsche 981S
The coyote should be putting out around 600 rwhp with that combination and run low 11s or high 10s. However, on street tires, who knows.
camaro-dreamer is offline   Reply With Quote
Old 10-08-2013, 10:11 PM   #5
Nightmare2012
come find out;)
Lol OK but if my builder asks you didn't get them from me ha 246/254 650/638 114 lsa mine hasn't been on the dyno yet since its still a build in progress he has 1500 miles on his setup dynod at 634/586 iirc his best time on drs is a 10.94 and on street tires a 11.3-11.6 depending on burnout
Old 10-08-2013, 10:16 PM   #6
trademaster
Drives: 12 MP4-12C, 16 Quattroporte
Whoever launches closer to idle lol. Unless you guys are running 33X+ rear tires, neither of you are going to get traction in first for the life of you.
trademaster is offline   Reply With Quote
Old 10-08-2013, 10:20 PM   #7
JEFF75645
I wont say nothin. Man I like those number.
Old 10-08-2013, 10:21 PM   #8
Nightmare2012
come find out;)
Lol do those tires even fit on our cars?
Old 10-08-2013, 10:22 PM   #9
Nightmare2012
come find out;)
Whose his? Yea his car is fastno doubt!!!
Old 10-08-2013, 10:24 PM   #10
trademaster
Probably not without some, "convincing," but that's what you would need in any normal street tire. Get some super sticky tires in the widest tread you can fit. Otherwise that car is going to be horrifying at anything under 60mph. You are talking 2013 gt500 #s with shorter gearing. It will be burnout city for both of you.
Old 10-09-2013, 12:19 AM   #11
Nightmare2012
come find out;)
Yea hopefully the m/t drag radials would be enough to help me hook
Old 10-09-2013, 12:56 AM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
Kinda hard to say but if traction is good you might take the win. You both might be in the same power level but keep in mind stangs are light.
62nalide is offline   Reply With Quote
Old 10-09-2013, 02:47 AM   #13
BlaqWhole
Drives: 2017 Camaro ZL1 A10
In this weather, cool and breezy with low humidity, I'd give the win to the Mustang on account of the fact that it is forced induction. Plus, if he has a more aggressive race tune, then he will definitely have an advantage. Forced induction will respond more drastically to cooler weather and mods including tuning. So even if you have an aggressive race tune to use, his will probably make more of a difference. You have more hp and tq but he has a lighter vehicle (yes we all know this). And if I'm seeing things correctly, you said his best time is a 10.9 on DRs and mid to low 11s on streets while yours is a 12.4 with your current set-up. Is your new set-up gonna give you a 1-1.5 second drop in the quarter? Is it possible that he can safely pulley down or add some other induction or exhaust mod to get a bit more out of his set-up?
BlaqWhole is offline   Reply With Quote
Old 10-09-2013, 09:49 AM   #14
87GNX
87GNX's Avatar
Drives: Alot
The stang no question.
87GNX is offline   Reply With Quote
