Roto-Fab
Old 09-08-2013, 02:50 PM   #1
dizz81
Wasting Gas
Drives: 2012 Black 2SS/ZL454
Do I need a new tune??
Hey all,
Hopefully this is an easy question to answer, and I'm pretty sure I know what the answer is going to be but just need confirmation.
My car is tuned for 93 octane and I just got stationed in Socal and all I find is 91. Do I need to get a retune for the lower octane? How bad is it running on 91 octane when I'm tuned for 93?
Thanks,
Cam, Headers, CAI, UDP, SLP LM II, 470/425
dizz81 is offline   Reply With Quote
Old 09-09-2013, 10:50 AM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
Higher octane tunes usually mean more timing. Octane usually decreases as elevation increases (since the air is less dense). Depending on your new elevation and assuming your car is N/A, there might be nominal difference.
However, as the car detects Knock Retard (KR), it will interpolate between the High Octane (HO) Spark table and the Low Octane (LO) Spark table. Once the KR hits some magic number, the car will just shift to the LO table to protect the engine. It will stay there until the fuse pull trick that forces the reset. I'm assuming that your tuner left the LO table with less aggressive timing than the HO one.
So, should you get it re-tuned? Probably so, but see how it behaves first.
Jack Bilger
granatl is offline   Reply With Quote
Old 09-09-2013, 07:19 PM   #3
SmokiNstripes6913
Drives: 2013 Camaro 1LS
Its probably not worth it to waste money on another tune. Its not like the 93 will hurt anything, your ecu will just use a lower octane fuel mapping like granatl stated.
SmokiNstripes6913 is offline   Reply With Quote
Old 09-10-2013, 01:24 PM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by dizz81 View Post
Hey all,
Thanks,
I would suggest getting a tune for 91 octane.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 09-11-2013, 09:13 AM   #5
Denis
Denis's Avatar
Drives: 2010 SS
im in a similar boat...i just came from Cali to the east coast and they have 93 out here. wonder if its worth getting a re-tune to take advantage of it...not sure if its worth the money
Denis is offline   Reply With Quote
Old 09-11-2013, 09:15 AM   #6
JANNETTYRACING
Absolutely it is only 55.00 for you since I just tuned your car.
Old 09-11-2013, 09:35 AM   #7
Mike@HennesseyPerformance
Mike@HennesseyPerformance's Avatar
Drives: 70 Camaro
Anytime you have lower octane than your car is anticipating you need to re-tune.
The risk/reward ratio just isn't there. Be safe, be smart, re-tune.
Mike@HennesseyPerformance is offline   Reply With Quote
Old 09-12-2013, 09:03 AM   #8
dizz81
Wasting Gas
Thanks for the info guys, really appreciate it.. Now to find a tuner out here..
Old 09-12-2013, 09:36 AM   #9
JANNETTYRACING
I can Help you.
Ted.
