Roto-Fab
Old 02-02-2014, 10:06 PM   #1
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
Can you use Pedder Camber Plates with any strut/coilover?
Found a set of Pedder Camber Plates for the Gen 5, I have a 2014 1LE, plan on using OEM struts/springs for another year or so before I jump to coilovers. Will the Pedder camber plates work with both the OEM struts and other coilovers such as BC/ridetech/pfadt. Thx for your input, Tom
tw78911sc is offline   Reply With Quote
Old 02-03-2014, 04:16 AM   #2
sting808
Drives: 2010 SS RS
They should work with any coil-over that uses the OE upper hardware mounts. Ridetech said modification is needed for theirs. Not sure if ride height will change when used with the OE struts. I needed to re-adjust my coil-over height when I replaced the OE upper hardware with Pedder camber plates. I am using the Pedders/BC racing style coil-over.
sting808 is offline   Reply With Quote
Old 03-15-2014, 10:07 AM   #3
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Just pick up some BC racing coils cheap on here and be good. Better than stock.
L99CAMA2011 is offline   Reply With Quote
Old 03-15-2014, 11:14 AM   #4
Rob@WretchedMS
Drives: His Wife Crazy
The will work with Pedders and BC Coilovers
If i can help with getting you a set of coilovers let me know.
Rob@WretchedMS is offline   Reply With Quote
Old 03-15-2014, 01:16 PM   #5
marolf101x
Drives: 2010 Test Mule
We are supposed to be getting a set of Pedders mounts sent to us.
When I get them I'll make something so you can use the Ridetech coil overs with the Pedders mounts.
Not yet sure if we need to make anything at all. But I'll know for sure once I get the mounts.
Skunk Werks
Ridetech
www.ridetech.com
marolf101x is offline   Reply With Quote
Old 03-15-2014, 01:28 PM   #6
Synner
Drives: cars
The shaft on ridetechs is thicker than the hole in the plates.
Synner is offline   Reply With Quote
Old 03-15-2014, 01:47 PM   #7
marolf101x
Though our shaft is 7/8" we step this down to 14mm at the plate.
We use a COM12 bearing in our plate (3/4" ID), with an aluminum adapter to go from 14mm to 3/4". This also sets the height of the unit.
So if the Pedders plates use a bearing with 3/4" ID our parts fit without modification.
If it's something else I'll have to make a new adapter.
Skunk Werks
Ridetech
www.ridetech.com
Old 03-15-2014, 03:07 PM   #8
Synner
Drives: cars
The upper portion has a pass-through of .7". The lower spring perch piece does appear to be a .75" ID on the bearing but the machined connector that fits into the upper portion is .7" again. ID of the connector is .567".
I really don't want to press out the connection piece to ensure a precise measurement since there's currently zero product support for them and I could easily dork up the bearing.
Old 03-15-2014, 03:44 PM   #9
marolf101x
that's cool. Can you post up some pics. mainly the ID of the bearing with a tape measure or caliper showing the dimension?
thanks!
Skunk Werks
Ridetech
www.ridetech.com
Old 03-15-2014, 04:36 PM   #10
Synner
Drives: cars
Don't have enough hands to do both so I will add pics and a better description, you'll just have to trust me.
Spring perch top. The pressed in piece in the bearing, OD .707", ID .561"
The spring perch slips into the upper portion to be positively located/centered.
Spring perch bottom. This is the one I can't get perfect without pressing things out so I just looked up the specs here, Koyo bearing 6204Z. ID 20mm, OD 47mm, 14mm thick
http://www.xbearings.com/p/koyo-6204z-p45253.html
Upper portion top. .702"
Upper portion bottom, same measurement as above.
Old 03-15-2014, 04:42 PM   #11
Synner
Drives: cars
The main issue I see you needing to get around is if you just press out the piece in the bearing then you will create a fitment issue with the top. It requires standoff so you would need to space it somehow without affecting bearing function.
Granted I have no idea what your shock looks like and I don't know what the tapered portion looks like that you're speaking of.
The top nut has a collar of the same dimensions as the brass piece above to fit into the upper mount. Thats the other issue.
Old 03-28-2019, 10:50 PM   #12
rabidryan805
rabidryan805's Avatar
Drives: 2011 Camaro 2SS/RS
Reviving an old thread but has anyone confirmed that Pedders camber plates will work with Ridetech coil overs?
rabidryan805 is offline   Reply With Quote
