04-09-2024, 07:03 PM | #1 | |
driveshaft carrier jxb
have you guys seen this carrier? seems like it really holds the driveshaft from vibration.
22% lower/ 2.5 upper/ 2 headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5 intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2 lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
04-09-2024, 08:39 PM | #2 |
Anthony S
I know there was a guy on the Facebook pushing these for awhile. The company makes allt of the driveshaft carrier bearings, but they only just recently built one for the 5th gen camaros. Everyone who bought one spoke very highly of the install. If I were going to keep the 2 piece driveshaft, I would probably make the switch. However I went with a one piece from DSS and haven't looked back since.
04-10-2024, 05:02 AM | #3 |
seems like a cheaper alternative to than going full dss or gulfcoast driveshaft. With all the vibration issue I keep hearing about with those $1000 plus driveshafts i might just give it a try. Not having a lift really keeps me from buying parts that require me to lay on my back in the garage. I'm getting too old for that.
04-10-2024, 07:31 AM | #4 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
04-10-2024, 08:56 AM | #5 |
I agree Andrew. If your car is a track car then for sure a one piece is far superior. But for a street car that never sees the track than i think it probably sufficient.
04-10-2024, 09:42 PM | #6 |
I have a 1 Piece Gulf Coast shaft and I also purchased this, I may put this on the Stock shaft and try it. I have the 1 Piece in the car but I am fighting a vibration so I took it out for the moment.
04-11-2024, 04:58 AM | #7 |
If you do, report back Joe. would like to hear your thoughts.
04-11-2024, 05:06 AM | #8 |
Will do, I want to get a new bearing, I'd like to keep the owm carrier in usable shape and not cut it to install this.
04-11-2024, 05:10 AM | #9 |
are the factory carriers discontinued like everything else.
04-11-2024, 06:01 AM | #10 |
Yes they are, and only ones I am finding appear to be cheap replacements.
