05-08-2024, 01:59 PM | #1 |
Drives: 2021 ZL1 1LE Join Date: Apr 2018
Camaro ZL1, LT4. E85 tune = Broken HPFP
Hi all.
2021 Camaro ZL1, LT4 engine, Manual Trans. Mods: 2" Headers, Intake, Cat delete, DSX flex fuel Sensor. Curious if anyone has come into issues with a failed High Pressure Fuel Pump (HPFP) after doing an E85 tune. Got my car up to 55% Ethanol, did a few pulls and after the last pull my HPFP dropped right off to 50psi. Codes: P228C - Fuel Pressure Regulator Control Performance - Low Pressure, P0089 - Fuel Pressure Regulator Performance. I was dialing in my last tune, verifying if my low-pressure fuel could supply up to 50-60% Ethanol. I didn't expect my HPFP to break; Curious if it could be related to my tune? I'm scared to run E85 now. FYI: I just ordered a Fuel pump voltage booster & a new stock LT4 HPFP. Any help greatly appreciated. I can provide the log if anyone's interested in giving me a second opinion
2021 ZL1 1LE Satin Steel Grey
05-08-2024, 02:09 PM | #2 | |
05-08-2024, 02:11 PM | #3 | |
05-08-2024, 02:21 PM | #4 | |
IPW average bank 1 & 2 = 5.3ms Ya I understand its too much E, I wanted to find that limit. But breaking a $1000 HPFP was not something I thought was going to happen. Could the pump be over-spun? Could I be asking too much of the pump? High pressure fuel at WOT ranging from about 2850-2950, Then around redline it spikes to 3200psi sometimes, not all the time. Car barely starts right now, cranks for like 20 seconds then starts and my High pressure fuel is at 50-60psi. The HPFP is broken I guess?
05-08-2024, 03:33 PM | #5 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
Have you considered adding a JMS fuel pump booster or Aux Pump for the low side? When I had my stock setup with 2" headers, stock blower, stock pulleys and misc. other mods, I was only able to get to E60, but it required the JMS Fuel Booster. That or install an Aux pump system. The JMS seemed to be to be a lot less "F'n" with the car as you don't need to drill the tank etc. etc. ? Also, did your tuner give you an E mix that they said was ok/safe to run?
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper w/18% 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | E85 | Brisk RR14S Plugs | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | MightyMouse Wild 1000HP CC | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned
05-08-2024, 04:28 PM | #6 | |
05-08-2024, 05:16 PM | #7 |
So... this was my fuel pressure with no E mix during a pull in Mexico! (see photo)
Also, below is the link to my complete build log and specifically post #215 is where I install my JMS Fuel Booster! Good luck! https://www.camaro6.com/forums/showthread.php?t=611982
05-08-2024, 05:43 PM | #8 |
Sent your logs to Megahurtz or KingLT1 and let them have a look.
05-08-2024, 06:36 PM | #9 |
Scratching my head on the high side pump taking a shit... I would have thought something much worse would have happened if the high side leaned out! I wouldnt think it running out of fuel would have damaged it? I could be wrong though!
2019 COPO #32
427 NA 9.38 142MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
05-09-2024, 08:41 AM | #10 |
It's just coincidental...the ethanol didn't make your pump crap out. Not sure how your tuner could have screwed up your pump either unless he was for some reason commanding more rail pressure than what the LT4 can tolerate.
2016 NFG 1SS A8
