BeckyD @ James Martin Chevy
Old 11-24-2018, 10:46 AM   #1
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
SS vs. SS 1LE wheel calculations
For those interested, here's calculations on the SS and SS 1LE wheels to quantify how much further in and out they sit compared to each other.
Old 11-24-2018, 01:25 PM   #2
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Thanks, saved for next year's little upgrade research
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 11-24-2018, 02:40 PM   #3
JeffFox
Drives: 2018 2SS Coupe A8
Thanks
Good info.
JeffFox is offline   Reply With Quote
Old 11-24-2018, 04:01 PM   #4
x_jarhead
x_jarhead's Avatar
Drives: 2018 1SS 1LE
Great info. Another interesting data point is rolling diameter. I’ve gathered a bunch of data comparing the diameter of 285/30-20, 305-30/20 against 305/30-19 when searching for track tires and wheels.
Using the stock Goodyear Eagle F1 Supercar 3R tires the measurements for the 1LE are:
285/30ZR20 26.8” diameter and 781 revs/mile
305/30ZR20 27.2” diameter and 767 revs/mile
Track tires
305/30 ZR 19 26.3 diameter and 796 revs/mile
You might want to add this data to your table...
x_jarhead is offline   Reply With Quote
Old 11-24-2018, 05:41 PM   #5
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
Track tires
The rev's per mile is what GM uses for the speedo, for any of the I4, V6, SS, SS-1LE and the ZL1 cars the revs per mile only vary I think 30 revs, so GM uses the same number for all of them. The ZL1-1LE may use a different calculation since its tire size has a decent amount of difference in the revs per mile.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
TJay74 is offline   Reply With Quote
Old 11-25-2018, 08:36 AM   #6
vtirocz
vtirocz's Avatar
Thanks for the input. I've updated the table with revs/mile and also added the ZL1 1LE size wheels/tires.
Old 11-25-2018, 10:51 AM   #7
Jcvibby
Drives: 2017 SS 1LE
Only thing to add is bolt pattern?
Jcvibby is offline   Reply With Quote
Old 11-25-2018, 11:12 AM   #8
vtirocz
vtirocz's Avatar
Thanks for the feedback. The bolt pattern for all wheels listed in post 6 is 5 X 120mm.
Old 11-01-2019, 01:26 AM   #9
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
I could add 1LE tires to my SS, no problem right?
YoungFamous is offline   Reply With Quote
Old 11-01-2019, 07:15 AM   #10
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Wheels and tires yes, just tires no.
TheRealJA105 is offline   Reply With Quote
Old 11-04-2019, 09:49 AM   #11
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
So, will I need to do the driverside wire relocation for the new 1Le wheels I bought if I stick to the stock 1LE tire sizes?
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 11-07-2019, 12:07 PM   #12
TheRealJA105
Drives: 2013 C6Z06
No
