Old 12-23-2013, 12:36 PM   #1
lspower62
lspower62's Avatar
Drives: 2010 White 2SS m6
NPP EXHAUST QUESTIONS
Hey i was just wondering if i added NPP dual mode and npp in a box, would it work like the vetts do? I want the flaps open at startup then closed while idling but open under hard throttle just the the z06 automaticlly. its a 2010 ls3. I dont like how the camaro dual mode is open at idle all the time then closes then opens under acceleration, just sounds dumb to me. thank you
Corsa Cb, RX catch, Vararam, LT Headers catless, slowhawk tuned, 20% tint, hks1inch lowering springs, zl1 20x11 wheels, nt05's, aac side-markers, more comingl ...
lspower62 is offline   Reply With Quote
Old 12-23-2013, 01:41 PM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
no there is nothing on the market that will give you exactly that.
Old 12-23-2013, 02:08 PM   #3
Sickness91Z28
Reaper Crew
Sickness91Z28's Avatar
Drives: Blown 2010 Camaro SS
Couldn't you just do the wild to mild set up?
2010 Camaro SS
SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP
Pedders XA Coilovers
Sickness91Z28 is offline   Reply With Quote
Old 12-23-2013, 02:33 PM   #4
lspower62
lspower62's Avatar
i was thinking about the mild2wild but is there a normal mode where it acts like a stock vette exhaust flap system?
Old 12-23-2013, 05:01 PM   #5
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
For the Camaro NPP you have 2 choices. ADM Exhaust controller with 2 modes, 1 being always closed and the other being factory mode(open @ idle/start-up and at WOT, closed up until around 3K I think). The other option is M2W, which is always open and factory mode. Sadly that is all there is in the market right now. I feel your pain.
Old 12-23-2013, 08:15 PM   #6
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
This is not true. If the car wasn't equipped with the NPP exhaust from the factory, the mild to wild switch will not work like factory. You will have control of the flaps. Either open or closed with the push of a button.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 12-23-2013, 08:26 PM   #7
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Sorry I guess 'factory installed' NPP would have been more accurate.
Old 12-23-2013, 09:49 PM   #8
lspower62
lspower62's Avatar
So theres no controller that will make the exhaust work like factory?? Damn :(
Old 12-23-2013, 10:07 PM   #9
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
If you just run a vacuum line from the intake to the mufflers when you crank the engine they will be open for a few seconds and then close and will stay closed until you step on the throttle and the manifold vacuum will drop and the mufflers will open as soon as you let off the throttle the mufflers will close!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 12-27-2013, 06:02 PM   #10
ZooDad
ZooDad's Avatar
Drives: 2010 Camaro SS/RS
That's what I did. Works great sounds great.
Sent from my SCH-I545 using Tapatalk
ZooDad is offline   Reply With Quote
dual, mode, npp, nppinabox
