02-22-2024, 05:47 PM | #211 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Was surprised by the M2’s time but then I saw what tires were on it.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
02-25-2024, 10:32 AM | #212 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
02-25-2024, 04:52 PM | #213 |
lb/hp works out to almost exactly the same.
04-26-2024, 07:54 PM | #214 |
In the most recent Car and Driver there was a comparison of a manual M2 and a manual Darkhorse. The Darkhorse had the $5,400 track package, but still lost the comparison. And the M2 as tested was cheaper at 75k while the Darkhorse was more expensive at almost 79k. That's crazy expensive.
04-28-2024, 09:33 AM | #215 | |
04-29-2024, 03:06 AM | #216 |
Drives: SS 6 speed of course Join Date: Jan 2016
I'm on the opposite side of this thinking, seeing the C8 at MSRP, I'd be a fool to buy a Mustang or Dark Horse and even bigger fool to put money into it like a blower. The C8 is better in every way possible and the C8 is NOT my favorite Vette. 70K for a Mustang is just crazy...
04-29-2024, 07:32 AM | #217 | |
04-29-2024, 08:45 AM | #218 | |
Adding a blower to the Mustang will certainly add power, but you would still have to spend another 10k to do that right.
04-29-2024, 09:22 AM | #219 | |
I agree that adding a blower will be 10k (I’d even say more like 12k) but from what I have been seeing these new Gen iv cars are making crazy power with just a blower swap. The dark horse has forged rods. i won’t be surprised at all seeing dark horses living at 900whp on sbe. If I decide I want a physically newer car than what I have GT/Darkhorse are literally the only option for me because I refuse to give up a manual transmission.
04-30-2024, 05:25 PM | #220 |
Go look on gen14f150 forums. they are tearing up bottom ends with blowers on the conservative warranty tunes. Seems like things aren’t so bullet proof on the latest gen coyote
04-30-2024, 05:31 PM | #221 |
The Gen3 Coyote shortblock is roughly 50% stronger than the LT1, and on par with the LT4 for $20K less… My brother is currently at 903 WHP with his stock-shortblock ‘23 GT…that’s not happening on an LT1. Ford certainly has its faults and as the owner of both a Mustang and a Camaro, I can say that with confidence lol. But the Coyote is a great engine, especially in Gen 3 guise. And FWIW, most of the Coyote guys having issues are trying to run boost with 12:1 compression and 91 octane LMAO. That’s a problem for any engine.
04-30-2024, 08:11 PM | #222 |
Maybe the truck ones are a little different than the Mustang ones. I’m not as well versed anymore on the truck vs mustang coyote differences but I know on prior generations things like compression, cams and intake manifolds were different. Could also just be first year gremlins. The Gen 3 coyote had issues in year 1 as did the Gen 1 coyote and the LT1 initially in the C7. I can’t see Ford having gone backwards with this new generation of Coyote.
04-30-2024, 08:46 PM | #223 |
If you are entertaining thoughts of getting mustang and adding a blower to increase power (and torque!) you might want to consider the limitations of the Tremec M6.
If my memory serves correctly, the DH doesn't use the TR6060, but rather the somewhat less stout Tremec (3160? can't remember the model number). Anyway, presumably Ford did that to save money and because they could get away with it given that the OEM coyote makes considerably less torque than the LT1. But if you significantly raise torque in the coyote....... Maybe experience has proven otherwise, but just thought I'd raise some food for thought so you don't wind up regretting future choices. |
05-01-2024, 01:42 PM | #224 | |
