dave@hennessey
Old 03-02-2018, 05:37 PM   #1
supashane
supashane's Avatar
Drives: 2011 Camaro SS L99
ZL1 fuel pump on n/a SS
So my stock fuel pump bit the dust today and I'm looking to replace it. I was pricing a new one today and noticed that the ZL1 pump isn't that much more expensive. Are there any drawbacks/benefits to running the ZL1 pump in the SS? I noticed a lot of people ran it in their SS, but mainly after going with a forced induction setup. I don't have many mods currently and will remain n/a for a couple of more years. With that said, is it even worth upgrading the fuel pump? I do plan on a cam within the next year or so. I'm ok with sticking to the stock pump, but was just curious of options since I was going to be going through the trouble of replacing the pump anyway. 2011 Camaro SS L99, Specs are in sig. Thanks
*SOLD* 1997 Camaro L36, Arctic white, manual, stock af
supashane is offline   Reply With Quote
Old 03-02-2018, 05:52 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Unless you use a ZL1 Fuel Pump Control Module you won't notice anything it'll operate as a SS pump, once you add the ZL1 FPCM then you'll notice a difference with different injectors.
Orange Krush II
Old 03-02-2018, 05:52 PM   #3
jaysanti
jaysanti's Avatar
Drives: 2013 Camaro 2SS/RS
Interesting point, look forward to hear what other's have to say.
Follow Me @ssatann_ss
jaysanti is offline   Reply With Quote
Old 03-02-2018, 05:58 PM   #4
hou30guy
Drives: 2011 convertible 2ss/rs
Got a ss pump for a 100 plus shipping
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 03-02-2018, 06:01 PM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
long term goals? short term...do it! per above until FPM runs like stock but WTF...when/if(and you will!) step up N/A the hard part is done.
and lookup how to cut (CAREFULLY) thru the sheet metal under the rear seat right above where the access port is located...unless you WANT to drop the rear cradle(LULZ)...
lots of peeps on here sell them for cheap...new is like $214 or $241 is(damn dyslexia!) any way for me it would be a no brainer...good luck OP....peace.
frankwjr is offline   Reply With Quote
Old 03-03-2018, 06:31 PM   #6
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
The 1le come stock with the zl1 fuel pump.
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
Powered1le is offline   Reply With Quote
Old 03-03-2018, 10:33 PM   #7
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
You need a FPCM to make it work.
Outlaw77 is offline   Reply With Quote
Old 03-03-2018, 10:40 PM   #8
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
I would upgrade to the ZL1 it’s all pretty much plug and play. I wouldn’t want to be dropping the fuel tank more than once, (trust me been there done that!) Good Luck.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-04-2018, 01:43 AM   #9
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
As others have stated, the ZL1 pump is a direct plug n play drop in so zero modifications are needed. It will work just fine for all but the most insane n/a builds and even be good for mild FI if you ever decide to go that route
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty
alaskacamaro is offline   Reply With Quote
Old 03-04-2018, 07:48 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
There is a way to cut the right area out under the passengers seat in back over the area of the floor pan to make a square patch panel cover the area with some caulk/rtv and not drop the tank BTW. It was a DIY post so maybe you can find it there, good luck.
Old 03-04-2018, 12:44 PM   #11
supashane
supashane's Avatar
Thanks guys, you're awesome. that's what I needed to know. And definitely going the cut out route when it's time ��
Old 04-07-2021, 01:11 PM   #12
Tool131
Tool131's Avatar
Drives: 2010 Camaro SS2
https://www.camaro5.com/forums/showthread.php?t=419632
2010 2SS M6, Procharger, 8 rib, 12lbs, E85, Holley intake W/ fuel rails, TSP Blower cam 229/242 w/springs, Harden pushrod, FIC injectors, DSX Aux. fuel, Kooks long tube headers, xpipe, no cats, Mcleod twin disc, G Force Axles, DSS aluminum drive shaft, Detroit Trutrac, LPW dif cover w/BMR bushings, BMR Toe rods and Trailing arms, 5 Stars, M.T. E/T Streets, Hurst short throw, Mighty Mouse catch can, 702 WHP on Mustang Dyno 10.7 1/4 Mile
Tool131 is offline   Reply With Quote
Old 04-07-2021, 01:26 PM   #13
Bo White
Bo White's Avatar
Holy 3 year old thread Batman
Totalled:
Old 04-07-2021, 02:14 PM   #14
Roader
Drives: Camaro
Need to get that post count up
Roader is offline   Reply With Quote
