Old 03-01-2018, 07:32 AM   #1
111MOTORSPORTS
111MOTORSPORTS's Avatar
Drives: Black 2015 rs
E-85 on stock injectors and fuel system
Im currently putting together a freshly built 6.2l ls3 with a texas speed stage 3 cam and full bolt ons. I already know what the car is most likely going to make so i want to step it up. Is it possible to run e-85 on the stock injectors with a cam and full bolt ons?? Also the car has a zl1 fuel pump.
111MOTORSPORTS is offline   Reply With Quote
Old 03-01-2018, 07:38 AM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
At least get lsa injectors or better yet 850cc
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 03-01-2018, 07:53 AM   #3
hammdo
'It's an experiment'
hammdo's Avatar
http://www.camaro5.com/forums/showth...&highlight=E85
This should help you decide:
-Don
747 RWHP 794 RWTQ
Old 03-01-2018, 08:09 AM   #4
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
I recently converted to E85 and upgraded from a Zl1 pump with 65 lb injectors to a Fore twin pump system and 1050 lb injectors. The ZL1 pump and injectors would not deliver E85 from the tank to the motor.
I did pick up about 70 hp to the tires with the upgrade. I'm also FI, but I hear non FI cars upgrading to E85 don't pick up a lot of hp.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 03-01-2018, 08:10 AM   #5
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
I maxed my bolt on cars injectors on E60 at 470ish swapped to LSA and had room to grow with them. Ended up making 475/473 with it.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 03-01-2018, 08:11 AM   #6
lazerlemonta
Drives: 2010 C6 1LT
I picked up 30 torque below peak and 12 horsepower. It is a significant change IMO
Best MPH 134.82
Old 03-01-2018, 08:12 AM   #7
hou30guy
Im waiting to know my numbers today on e85 and dual 450 pumps and 20 psi boost and 1400cc injectors
Old 03-01-2018, 08:41 AM   #8
111MOTORSPORTS
Originally Posted by hammdo View Post
Wow only 2.5 rwhp gain! Thats crazy, I will probably just do ported heads, TB and a ported intake. Thanks!!
Old 03-01-2018, 08:43 AM   #9
hou30guy
Still gives ya fuel options when 93 oct shoot back through the ruff this summer
Old 03-02-2018, 08:24 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
Yup N/A most builds makes no sense to run corn its for power adders............And not run all that extra fuel into the oil....AS your mileage goes to crap just Corn also, and its yup bad for the environment also ...LOL sorry greenies its proven to be a truth......
Old 03-02-2018, 11:48 AM   #11
111MOTORSPORTS
Yea, My tuner says that with my current setup i should pick up around 15-20whp the 93 price in my area is already high!!!!! Does anyone know what size injectors i should run? From what i hear the zl1s will be close to maxed out if not maxed out completely.
Old 03-02-2018, 12:08 PM   #12
Bo White
Bo White's Avatar
I'm heads and cam LS3 making roughly 600hp or better at the crank and my LSA injectors are maxed on E85. I have CTSV pumps.
Totalled:
Old 03-02-2018, 12:09 PM   #13
Bo White
Bo White's Avatar
Get the flexfuel injectors. Slightly bigger than LSA and cheaper.
Totalled:
Old 03-03-2018, 08:28 AM   #14
christianchevell
your pic shows a v-6 on your name....... you thinking of swapping in a v-8, god help you.....
