01-13-2018, 09:54 PM | #1 |
Drives: 2023 Camaro SS 1LE on order Join Date: Dec 2014
E85 conversion
I'm thinking about doing E85 conversion, do I need to replace the lines? I've read lots of posts and some say yes and some say no. I have a ZL1 pump and I know I would need the flex fuel adapter and injectors just not sure about other lines.
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
01-13-2018, 10:03 PM | #2 | |
'It's an experiment'
I didn’t change mine. Older cars would be an issue when there were built before they added ethanol into the fuel — I Believe that was 2002 when they started putting ethanol in gas... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
01-13-2018, 10:05 PM | #3 |
Fuel lines will be fine, contact dsx they can answer all you questions, the zl1 pump will be the biggest limitation after you change the injectors
Cai intake and a few other mods😎
01-13-2018, 10:07 PM | #4 |
+1 on DSX...
-Don
747 RWHP 794 RWTQ
01-13-2018, 10:08 PM | #5 |
Awesome thanks!
01-14-2018, 02:43 AM | #6 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
With your setup, you’ll need to upgrade your injectors and switch to a duel pump fuel system. Lines won’t be a problem..
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty |
01-14-2018, 03:29 AM | #7 |
Do the duel fuel pumps require a return line?
01-14-2018, 04:22 AM | #8 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
You're going to need injectors and a fuel pump.
I logged my fuel pump. With just a Cold Air Inductions CAI, JRE scoop, BBK cat deletes and full Corsa catback, my injectors are at 90% duty cycle WOT and my fuel pump maxes out at 100% around 4k-ish rpm's. The E85 I ran was testing in at 73% alcohol.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite Last edited by John_C; 01-15-2018 at 07:15 AM. |
01-14-2018, 08:29 PM | #9 |
Drives: Z06 wannabe Join Date: Feb 2015
Rock on man, Im dreaming of E85 1 day.
Keep me posted, are you doing the work yourself?
Apex Focused
01-14-2018, 09:13 PM | #10 |
Not the DSX kit...
-Don
747 RWHP 794 RWTQ
01-14-2018, 10:15 PM | #11 |
Yeah I'll do it myself when I pull the engine, hopefully this spring
01-15-2018, 04:52 PM | #12 |
The system im running with e85 is a lpe twin pump with aug 850 injectors (996@58psi), this would be the Minimum set up i would run, and if i did it all over again i would of done 1k aug injectors, also this is using the factory lines, if your really thinking of upgrading you fuel system agp has a couple awesome systems
01-15-2018, 04:59 PM | #13 |
Thats what I have is the Lingenfelter kit.
Its CTSV pumps with a reflashed truck computer to my understanding. Im running CTSV/LSA injectors. 66% DC on 93 and 94% DC on E85.
01-15-2018, 08:06 PM | #14 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
I've got you covered for a full flex fuel conversion. My fuel system is super easy to install (well, the flex fuel kit is even easier), and it'll provide you fuel well up into the 900+ range on ethanol without breaking a sweat.
