05-21-2014, 08:39 AM | #1 |
Drives: G5.R Join Date: Sep 2010
OVER 200 LBS. IN WEIGHT SAVING IDEAS
Hey guys we have gotten a lot of PM's regarding advice on weight reduction options from members over the last two years and thought it be a funny idea to create a weight reduction thread were we can share and discuss different options on reducing perhaps some additional weight off the Z/28 as I know understand that GM is catering to the enthusiast market and this would be a topic of interest. We can discuss from mild changes that could be easy reversed to the more aggressive changes for the guys who aren't concern with collectibility factor 40 years down the road.
Perhaps you guys could share what your weight drop goals are and we can discuss different options on how to get there. So lets start and here some of the ideas, pros, cons, etc....... Perhaps this might become a "sticky" thread for other members to benefit down the road so lets try to keep it on topic! Last edited by Moreno1; 01-17-2016 at 07:03 PM. |
05-21-2014, 09:06 AM | #2 |
Drives: Z28 want Join Date: Mar 2014
No washer fluid
Take off Z/28 emblems ! Toss flow tie Rip out radio....... |
05-21-2014, 09:08 AM | #3 |
Drives: BAC Mono Join Date: Apr 2013
Excellent thread idea
1. Ti cat-back exhaust. Save 40 lbs? That's a guess. Approx $3k-4k. Only con is $ 2. LiON battery. Save 30+ lbs. Approx $1500. Only con is $. High-quality Lion exceeds lead acid in every way. That is your quickest, easiest, biggest lb numbers. I would have zero interest in anything that compromises the structure/safety. Maybe some kind of plastic/carbon intake, save 5 lbs? Big $$?
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28. |
05-21-2014, 09:32 AM | #4 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
Question -- is anything special required regarding charging, etc.? For some reason I recall this being an issue with first gen versions...
05-21-2014, 09:49 AM | #5 |
Drives: 2013 Cayenne GTS Join Date: Dec 2013
Go on a diet...
05-21-2014, 09:52 AM | #6 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Strip the paint down to the bare metal then use a tinted clear coat over it. That might save a couple pounds.
The Bird is the word! |
05-21-2014, 09:53 AM | #7 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
http://rearseatdelete.com/camaro5.html
I know the Z/28 has a lighter-weight rear seat as is, but this might be even less.... Pros: More cargo room.....(track tires).... Cons: Not usable for passengers....(No seat belts).... Last edited by 90503; 05-21-2014 at 10:04 AM. |
05-21-2014, 10:10 AM | #8 |
I haven't heard this one yet in the Z/28 section... CF one piece drive shaft. reduce some driveline weight, and at the same time you get rid of the slop that comes with a two piece.
OE wheels are beautiful, but not the lightest at 25-27lbs ea. We have forgeline Ga1R-OL and they are right under 21lbs ea IIRC Optic Armor front and rear windshields will save 20 lbs off the top of the car. all depends on how extreme you wanna go |
05-21-2014, 10:13 AM | #9 |
Going all "Silver Arrows" on us, eh?
05-21-2014, 10:28 AM | #10 | |||
What would a drive shaft cost? Weight savings?
2014 Z/28, White
05-21-2014, 10:31 AM | #11 |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
05-21-2014, 10:31 AM | #12 | |
05-21-2014, 10:33 AM | #13 | |
05-21-2014, 10:37 AM | #14 |
Well the $1500 ones will most likely have fail-safe computer tech in the battery to prevent full discharge, low/overvoltage, shorts, etc. Call lithium pros and they'll explain everything to you, as a lot of the tech is beyond me. LOL. from what I have seen, they have the most tech, and highest size/weight ratio... i.e. they are very light
