TireRack
Old 06-30-2014, 01:10 PM   #1
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Question L99 with low compression on AFM cyls only
2011 L99 completely stock internals with Maggie, 9psi, headers, rotofab, and solo catback
While on road course one of the h/f cats collapsed completely and car started running bad.
cruised it home and started checking it for problems and ultimately found the bad cat. It drove normal at cruise only ran bad under load.
Gutted cats, still ran bad........
Checked plugs, wires, injectors and compression etc
Found #6 low only 50 psi
Pulled head and piston was broken/cracked (same side as bad cat)
Replaced piston, rod, rings for cyl 6
Went ahead and eliminated afm lifters, installed all new ls3 lifters and trays, valley cover from Magnuson for LS3, new o rings and gasket from dealer. Cleaned out oil pan, screen etc (skirt had broken off piston also) AFM was already turned off in tune. Also installed new plugs and wires Stock vvt cam was left unchanged.
Car still runs bad. We turned on misfire counters in the tune and found all afm cylinders misfiring intermittently.
Checked compression again, all afm cylinders are at 150ish and all non afm cylinders are 190-200. So obviously this is the problem,
But my question is what could cause this only on those cylinders?
All valves, pistons, etc visually looked good and compression was pretty equal before piston was changed.(maybe all cylinders within 15 psi of each other, don't remember the exact numbers
Any ideas? Im starting to think rings are bad just doesn't make sense that's its on those 4 cyl only.
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 06-30-2014, 07:56 PM   #2
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
cam is probably an issue, vvt function is operated by oil in the front of the cam, I would go with the cam first. , potentially causing a premature valve to open. then check to make sure all valves are sealing and not leaking
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 07-01-2014, 01:39 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Can the stock AFM cam even be used with LS7 lifters? Also why not change to a small VVT cam with out AFM?
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 07-01-2014, 02:28 PM   #4
BplumCrazy-SS
BplumCrazy-SS's Avatar
Drives: 416 w/TH400
did you do a leak down test?
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
BplumCrazy-SS is offline   Reply With Quote
Old 07-01-2014, 02:39 PM   #5
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Just delete all that crap, swap out the cam and front cover so you won't run into issues also if you start to swap things out, if you haven't already, turn off the dod setting in the tune. You're computer is probably confused as to why parts aren't in working together and firing as if there're all l99 parts in there.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
Trob85 is offline   Reply With Quote
Old 07-01-2014, 03:33 PM   #6
Kelly@PCMofNC
Drives: 2010 RS/SS
If you delete the DOD lifters you need to change to a non-DOD cam as well.
Kelly@PCMofNC is offline   Reply With Quote
Old 07-01-2014, 03:53 PM   #7
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Cam was left in due to budget constraints. Lifters were swapped out because heads were already off to check all Pistons so it made sense to swap lifters since a cam was in the future plans. I just don't think anybody has ever done the lifter swap on stock cam.
gonna try that but its still at 150-160 compression so I doubt that will help. But I will ck compression on the cylinder with new piston and rod which is a afm cylinder. If that one is low, then I know for sure the piston or rings is not the issue since those are new.
I have an LS3 cam laying around so gonna use that for now. All the DoD/afm settings have been off since the s/c install a year ago. But it does seem that valve timing is off somehow. When I do a compression test on the low cylinders I only get 50-60psi on the first stroke and the higher cylinders give me 100psi on first stroke.
Why is that? Are the lobes different between them? That's what I've been wondering.
Sent from J-Rod's Continuum Transfunctioner
Old 07-01-2014, 06:34 PM   #8
Trob85
Svt lol
Trob85's Avatar
Swap the cam you'll be good to go.
Old 07-01-2014, 07:01 PM   #9
Who Dat 2SS
Who Dat 2SS's Avatar
Drives: Bitches Crazy
This one is my wife's baby. Thanks for the input!
www.h-towncamaroclub.com
2011 2SS Convertible Black on Black on Black, Magnuson TVS2300 Supercharger, LS3 Conversion, LS9 Cam, Kooks Ceramic Coated Headers, LS3 Exhaust, Roto-Fab CAI, BMR Sway Bars and Bushings, JDP Color Changing Halos with Synced Grill Lighting, Custom Magnetic Removable Front Plate
*** RECORD HOLDER - FASTEST 3 WHEELED, 7 CYLINDER CAMARO LAP TIME AT MSR ***
Who Dat 2SS is offline   Reply With Quote
Old 07-02-2014, 08:11 AM   #10
blisoachle
Drives: Camaro
blisoachle is offline   Reply With Quote
Old 07-02-2014, 03:23 PM   #11
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Yeah got an LS9 cam on the way
Yeah that's what it seems but wondering if the lobes are different between the 2 cylinders afm and non afm
Old 07-05-2014, 12:41 PM   #12
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
LS9 cam is in, VVT crap is removed.
All cylinders are equal compression now and Matt is working on the tune.
Old 07-06-2014, 12:48 AM   #13
Who Dat 2SS
All went well in the end. Was misfiring on a few cylinders on the dyno. Still had pieces of the melted cats in the muffler. Swapped the Solo catback for a stock LS3 catback and it cleared up. Made 500/480 on last pull. Needs a MSD BAP adjustment so it may have a few more horses in it.
Old 07-06-2014, 08:02 AM   #14
Trob85
Svt lol
Trob85's Avatar
Sweet glad it worked out and nothing broke internally.
