Vararam
Old 12-23-2017, 08:48 AM   #29
Bo White
Bo White's Avatar
the 6th gen is for one a different vehicle all together. I think it shares 1 part with the 5th gen. Its all new basicly. The engine is 11.5:1 so it will gain more on E85 and has direct injection so it has a lower injector duty cycle right off the bat.
Totalled:
Old 12-23-2017, 08:49 AM   #30
Bo White
Bo White's Avatar
Originally Posted by Gunmetal Speedster View Post
I'd take it with a grain of salt until you see a dyno sheet haha
Agreed. Ive yet to see anyone gain near that much n/a. No matter the engine.
Totalled:
Old 12-23-2017, 07:35 PM   #31
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
Originally Posted by Ashen L99 View Post
How is it that my 6th gen buddies were just able to get the flex sensor and run full e85? I have 2 that have done it. One car is a blue 16', A8, with a stall, small blower cam, full exhaust and e85. He is still NA. The other is a white 17', M6, with ported throttle body, full exhaust, and e85. They both claim it is 40 hp easy. Now this is all them talking a big game but I have yet to see dynographs. point is, they are both pushing me to get lsa injectors, zl1 fuel pump and the sensor so I can run corn. How is it that we aren't seeing the "gains" they are? You can't tell me the new LT1 is just that good...
Maybe he meant 40whp total with all mods done, not just E85? I was told 10-15whp (e85) was a normal increase with my setup. The larger tq increase was due to the cam I think...
Also, it looks like your l99 is a 14 or 15 model and I thought they started putting ZL1 pumps in all SS models by then?
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty
alaskacamaro is offline   Reply With Quote
Old 12-23-2017, 11:34 PM   #32
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
I spoke earlier today with my buddy with the blue a8. He baselined at 381 to the wheel. With all mods he is putting down 495. The switch from 93 to E85, it picked up about 30 hp. On our cars we get 2-10? Damn. The thing is, around these parts I only have access to 91. I wonder what I would pick up...
Where did you hear that the 14-15 models have the ZL one pump? I'm pretty sure the only thing I've heard of is that the 1LE cars have it, regardless of model year.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 12-24-2017, 01:37 PM   #33
alaskacamaro
From what I understand all SS 14 and 15 models switched to a ZL1 pump and electrical steering. I’m guessing Chevy wanted standardization after introducing the 1LE.
When I lived in Alaska I was stuck with 91 pump too. Had to add Teroco (1/4 can) per tank to improve octane level. With the Teroco added and all my mods I was dynoed 490whp and 460wtq. Of course every dyno is different and “numbers” are only part of the equation.
Like BO stated, 30whp raise on a n/a only engine seems very high. Usually huge gains like that are seen on FI engines using corn or meth...
Old 12-24-2017, 08:19 PM   #34
Ashen L99
Ashen L99's Avatar
Who can confirm this?
Old 12-25-2017, 05:15 PM   #35
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
I received the flex fuel sensor from DSX for Christmas. Will take me some time to actually get the injectors to go with it, but I'll be sure to do a before/after dyno as well since I'm N/A just to show the results. I plan on F/I way down the road so it will help in the end regardless haha.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 12-25-2017, 08:03 PM   #36
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Nice!!! Anxious to see the results
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 01-02-2018, 11:48 AM   #37
johnnyb305mia
Drives: 2015 Camaro SS 1LE
Curently on E85 i only run E85 no its not my daily and even if it was i would still only run E85. My set up is the following...
Intake
Gmpp exhaust
1 7/8th catless mild steel headers
Fuel crossover
OEM FF sensor
Howards ASA Cam
ZZP Pushrods
160 stat
950cc FIC Modded OEM Injectors
E85
305/45/18 Tire
Nitrous Outlet Plate Kit (100 shot)
johnnyb305mia is offline   Reply With Quote
Old 01-02-2018, 12:21 PM   #38
Bo White
Bo White's Avatar
Those 950cc injectors for future boost?
Nice that the 1LE has the ZL1 pump from the factory.
Totalled:
Old 05-24-2018, 06:37 AM   #39
Ashen L99
Ashen L99's Avatar
Can anyone confirm about the zl-1 fuel pump in the 14-15 Camaro SS’s?
Old 05-24-2018, 08:23 AM   #40
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
No they are different.
Baddbird is offline   Reply With Quote
Old 05-24-2018, 02:38 PM   #41
RyangAsh
Drives: 2014 ZL1
From everything I have seen, the 1LE's have a ZL1 fuel pump in them..not sure if this helps.
RyangAsh is offline   Reply With Quote
Old 05-24-2018, 02:41 PM   #42
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
1LE is the same as the ZL1 but the SS are different
