Old 07-02-2016, 05:57 PM   #57
Bhobbs
Bhobbs's Avatar
Hopefully that engine makes power way over 5000 rpm because that would be disappointing. That car should be making 700+ hp.
Old 07-02-2016, 07:51 PM   #58
ender2664
Drives: 2016 2SS
I was planning on my next car being the C8. But if the C8 goes mid engine I will be looking elsewhere.
ender2664 is offline   Reply With Quote
Old 07-02-2016, 09:02 PM   #59
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I'm on board either layout... my next car is a C8 unless it's hideous...
Firefighter is offline   Reply With Quote
Old 07-22-2016, 11:00 AM   #60
Drives: 2023 GMC Canyon, 2020 Colorado
http://www.gminsidenews.com/articles...ette-zora-lt5/
Speculative, but interesting.
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 07-22-2016, 11:07 AM   #61
Bhobbs
Bhobbs's Avatar
Interesting.
Old 07-22-2016, 11:45 AM   #62
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
DOHC???!!!! Isn't that sacrilege? Blasphemy!
Thor142 is offline   Reply With Quote
Old 07-22-2016, 12:17 PM   #63
ender2664
Drives: 2016 2SS
So a big reason I like these OHV engines is obviously the torque, but isn't it entirely possible that the DOC motor could make more hp at the top and equivalent or more torque at the bottom?
DOHC won't bug me if they don't shift the power band so high that it sucks everything out of the bottom of the curve.
Old 07-22-2016, 12:51 PM   #64
Denis
Denis's Avatar
Drives: 2010 SS
oh very interesting. Someone really dropped the ball if this is true.
Denis is offline   Reply With Quote
Old 07-22-2016, 01:26 PM   #65
Thor142
Thor142's Avatar
The problem is to get the big fat low end torque curve you need displacement. OHC is bigger just because you have all the cams sitting on top of the heads so it's tough to make a 6.2L DOHC fit into anything. They do however breathe way better and spin safely way higher. So naturally the powerband is in a different part of the RPM range. It seems if you want to keep an engine N/A you have two choices. Big displacement or big RPMs
Old 07-22-2016, 01:28 PM   #66
Bhobbs
Bhobbs's Avatar
If it's forced induction, DOHC can make some big numbers. The 5.8 Trinity made similar torque to the LS9 but made 30 more hp.
Old 07-22-2016, 01:33 PM   #67
Bhobbs
Bhobbs's Avatar
I wonder how the mid engine layout impacts engine packaging. They might be able to fit a larger displacement DOHC engine in a mid engine Corvette.
Old 07-22-2016, 01:40 PM   #68
ender2664
Drives: 2016 2SS
Damn good question imo.
Old 07-22-2016, 01:50 PM   #69
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
I mean they did fit the lt5 in the same spot as the lt1/4. It had decent displacement and anice powerband. Also i remember one build where they spun one over 9k. But i highly doubt they will care to make a big cube dohc with the way everything is going forced induction.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 07-22-2016, 02:00 PM   #70
Thor142
Thor142's Avatar
Hmmm....intersting. A 6.2L all aluminum DOHC. That would be a freakin BEAST!!!!! Or maybe a small displacement TT DOHC V8 powerplant.
