TireRack
Old 09-12-2022, 07:50 AM   #1
Migraine8
Drives: 02 Dakota - 2011 camaro 2ss
Transmission fluid recommendations
Im looking to change the transmission fluid and filter on my 2011 Camaro 2ss automatic l99
What fluid do you recommend and how many qts will I need.. thanks
Migraine8 is offline   Reply With Quote
Old 09-12-2022, 08:33 AM   #2
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
I just purchased the AC Delco Dexron fluid from rockauto. I'm not a mechanic or chemical engineer; just a guy driving a camaro. I try to stick OEM as much as possible. Your safest bet would probably be to grab some from your local dealership, but that will cost you more.
As far as the amount, you should check your owner's manual. I drive a V6 auto, and it took a little over 6 quarts if I recall (don't quote me on that). I did the temperature level set rather than the drain-and-replace-with-same-amount method.
ElderJ is offline   Reply With Quote
Old 09-12-2022, 09:26 AM   #3
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Anything Dexron VI is fine and around 7 quarts
NOT A 45 is offline   Reply With Quote
Old 09-12-2022, 11:38 AM   #4
Migraine8
Ok thank you I’m gonna buy some and have my local mechanic put it i. Gonna do the differential too
Old 09-12-2022, 11:50 AM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Most people will tell you the AC Delco Dexron is best, and in most cases I would agree.
Problem for me is that I cannot run that in my car without issues. The Delco fluid produced a terrible 2-3 shift flare whenever I ran it. I was able to completely eliminate it by running with Valvoline Max Life full synthetic ATF. Not sure why or what the difference is.
I am not recommending anyone else do the same, just stating what worked and didn't work for my trans.
InFiD3ViL is offline   Reply With Quote
Old 09-21-2022, 08:21 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Factory for me - I have a GPI modified setup with a ZL1 torque converter - road raced it. I also have a trucool 44k trans cooler for that...
Never tried the Valvoline Max but it may be a good option...
-Don
747 RWHP 794 RWTQ
Old 09-22-2022, 07:18 PM   #7
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Redline
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 09-22-2022, 08:20 PM   #8
xstuntman
Drives: 2012 Victory Red LFX
Mobil 1 HV LP.
xstuntman is offline   Reply With Quote
Old 09-23-2022, 06:53 AM   #9
NOT A 45
NOT A 45's Avatar
Originally Posted by xstuntman View Post
Mobil 1 HV LP.
That is not the correct transmission fluid for his Camaro. Fluid usage is as follows:
6L80 uses Dexron VI
8L90 uses Dexron HP
10L80 uses Dexron ULV
Why do they use 3 different fluids in 3 different transmissions? Use the wrong one and chances are you will find out!
