Old 04-28-2018, 05:22 PM   #1
babigguy
babigguy's Avatar
Drives: 2017 ZL1, 2015 Z51 vette 2005 gto
codes p0300 and p16a1 and p0157
ok so did some upgrades: halltech intake, katech ported tb, borla h pipe and granatelli plug wires. car started fine for a few minutes then felt sluggish and flashing check engine light came on with service stabilitrak and service rear diff light on dash checked code and was only p0300 so re-seated all plug wires and they are all good checked all hoses under hood and all connected. with getting the lean code do i need to get this tuned? not sure what the heck my issue is at this point?
babigguy is offline   Reply With Quote
Old 04-28-2018, 05:23 PM   #2
babigguy
babigguy's Avatar
Sorry 2015 c7 z51
Old 04-28-2018, 06:17 PM   #3
babigguy
babigguy's Avatar
ok went out to look at this again and changed out the tb to the stock one. cleared the codes and getting a permanent code of a p0300 and p16a1 with the pending code of a p0300 and the serv stabilitrack and serv rear diff and flashing check engine code
Old 05-07-2018, 07:09 AM   #4
babigguy
babigguy's Avatar
ok bought hp tuners and seeing a misfire on 7 and 8 how do the cylinders count on the block?
Old 06-13-2019, 03:28 AM   #5
rdanzel
Drives: 2010
Sounds like a misfire issue. Try replacing the plugs and wires.
rdanzel is offline   Reply With Quote
