Old 04-24-2013, 11:51 PM   #1
mc_acoustic
Drives: 2010 1LT Limited Edition Camaro A6
Which tires should I get?
I am looking for new tires for my 1LT camaro (2010)
I currently run P245/50R 19" tires.
I was thinking of something of getting slicks because i heard you can get some extra speed out of it... Is this true?
I am new to tires.... So i would love for someone to help me out!
mc_acoustic is offline   Reply With Quote
Old 04-25-2013, 12:58 AM   #2
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
Putting slicks on will not get u anymore speed or give u anymore horsepower for that matter. You have a V6 and unless ur car is making tons of power and breaking the tires loose there is no reason for u to get slicks. Slick are for track use as the are illegal on the street and dont do good in the wet. Slicks and water are a no no!. If u need tires and ur looking for a good set of tires that will give u better traction then u should look at a softer compound tire that has AA traction and A temperature for tire ratings. A good set of tires is all u might need. Many good companies out there like Michelin, Nitto, Bridgestone,...
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 04-25-2013, 06:22 AM   #3
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
If your going for the most Tread Wear(more Life) then it has to have a larger UTOG:IE:
TREADWEAR: 220
TRACTION: AA
TEMPERATURE: A
Nitto Motivo = UTQG: 560 A A (All Season)
Nitto Invo = UTQG: 260 A A (Summer Only)
Gmax as-03 = UTQG: 480 A A (All Season)
Falken 452 = UTQG: 300 AA A (Summer Only)(Front Original Size Only)
Perilli P Zero = UTQG: 220 AA A (Summer Only)
Hankook Ventus V12 evo K110 = UTQG:280 AA A (Summer Only)
Goodyear Eagle GT = UTQG: 400 AA A (All Season)
Firestone Firehawk Wide Oval AS = UTQG: 400 A A (All Season)
Continental Extreme Contact DWS = UTQG: 540 A A (All Season)
BFGoodrich g-Force Sport COMP-2 = UTQG: 340 A A (Summer Only)
Cooper Zeon RS3-S = UTQG: 300 A A (Summer Only)
VREDESTEIN ULTRAC SESSANTA = UTQG: 280 AA A (Summer Only)
Here's a good site for description of tires:
http://www.discounttiredirect.com/di...010&vid=016070
More Info: Uniform Tire Quality Grading (UTQG) Uniform Tire Quality Grading is a relative comparison system. Tires are graded by manufacturers in three areas: treadwear, traction and temperature.
The treadwear grade is a comparative rating based on the wear of a tire when tested carefully under controlled conditions. For example, a tire graded 400 should have its useful tread last twice as long as a tire graded 200. Treadwear grades are only valid for comparisons within a manufacturer's product line.
Traction grades represent the tire's ability to stop on wet pavement as measured under controlled conditions on asphalt and concrete test surfaces. As of 1997, the traction grades from highest to lowest are "AA","A","B" and "C". The grades do not take into consideration the cornering or turning performance of a tire.
Temperature grades represent a tire's resistance to heat and its ability to dissipate heat when tested under controlled laboratory test conditions. The grades from highest to lowest are "A","B" and "C" . The grade "C" corresponds to the minimum performance required by federal safety standard.
WHAT IS TPMS?
http://www.discounttiredirect.com/di...ticlePopup.jsp
Example for shipping Nitto Motivo to Quebec:
http://www.discounttiredirect.com/di...rt/viewCart.do
I just saw this for the threads on our tires:
CHECK TIRES THREAD DEPTH
GREEN = 8/32 or Greater
YELLOW = 7/32 to 4/32
RED = 3/32 or Less
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 04-25-2013, 08:45 AM   #4
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
TREADWEAR: 220
TRACTION: AA
TEMPERATURE: A
Man you left off Michelin Pilot Super Sport Tires....
lol.
Ir0nM4n is offline   Reply With Quote
Old 04-25-2013, 08:49 AM   #5
Arob
Xxcamar0-vettexX
Arob's Avatar
Drives: Red with black hood hockey stripes
No slicks unless you want to crash your ass into a building
Arob is offline   Reply With Quote
Old 04-25-2013, 09:12 AM   #6
RickRay
INJACC
RickRay's Avatar
lol.
I sure the're are a few more I missed...
