TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 08-04-2016, 12:46 PM   #1
Rat
Rat's Avatar
Drives: ZL1/TBSS/COPO
Shorter rear drag Wheel... HELP!
Hello All
Anyone here ever run a shorter rear wheel tire combo on a ZL1???
I put a Rep 18x11 wheel with Hoosier DOT Drag radials 315 30 R18. 26" tire Stock is 28".
As soon as I start moving then hit the breaks the peddle chatters and Stablitrack freaks out.
I'm thinking its the smaller diameter is making the computer unhappy!
Anyone run a combo like this and what did you do to make it work?
Pull the ABS fuse?
.....2012/14 COPO #33....427, 1.31 60' ....9.39@143......
Rat is offline   Reply With Quote
Old 08-04-2016, 12:53 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Some other guys have mentioned this and yes they pulled the fuses at the track. Your freaking out the ABS system with the shorter tires
HOJO is offline   Reply With Quote
Old 08-04-2016, 12:54 PM   #3
Rat
Rat's Avatar
cool I will try that out first!
Anyone know what number the ABS fuse is?
Old 08-04-2016, 03:24 PM   #4
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
40 and 43
2013 ZL1 #7860 is offline   Reply With Quote
Old 08-04-2016, 04:43 PM   #5
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
You could always go with a shorter diameter front. It should lower the weight of the assembly, too. Win-Win!
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 08-04-2016, 10:37 PM   #6
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
I run the ET street R (29" tall) on my Rep 18x11 setup and hasn't thrown any codes. Drives as good as the MT DRs on my stock 20s.
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 08-05-2016, 09:26 AM   #7
Rat
Rat's Avatar
Thanks everyone! Fuse pull and life is good again.
Few mods coming up but for now just wanted it to come out of the hole harder. So far so good.
#7860 and ZL1 kid you guys running the Super Chevy Show?
Old 08-05-2016, 11:47 AM   #8
ZL1Kid_AL
ZL1Kid_AL's Avatar
Clutch has been slipping in 2nd-3rd gear and I don't have no time to replace it, but I'll be there to show it off and just have some fun
Old 08-06-2016, 10:05 PM   #9
Deez-zl1
Deez-zl1's Avatar
Drives: 2013 camaro zl1
What set up works better, the stk wheels with mt,s or the rep 18's ? I am planning on ordering 18 x 11's next week. Im laying down 650 rwhp. Thanx
Deez-zl1 is offline   Reply With Quote
Old 08-06-2016, 10:35 PM   #10
ZL1Kid_AL
ZL1Kid_AL's Avatar
I ran ET street 2s when I was 650whp and they did the job at the track and decent job on the street, drove like stock.
I only have 2 passes on the new 18 set up but they flat out hook at the track, bogged both passes bad, gonna launch it higher when I get a new clutch and should get my 60 down... If planning to add more power go 18s now, if your at your stopping point just get the 20 DRs
Old 08-07-2016, 07:37 PM   #11
Deez-zl1
Deez-zl1's Avatar
What size and brand tire are you using on the 18's ?
Old 08-07-2016, 08:06 PM   #12
Deez-zl1
Deez-zl1's Avatar
Originally Posted by Rat View Post
Hello All
Pull the ABS fuse?
Im sure this is probably not do able, but here goes. Way back when i was kart racing, we used to stretch our tires to get the right height. Is it possible to stretch the hoosiers a bit?
Old 08-07-2016, 08:25 PM   #13
flyer08
Drives: 2010 2SS/RS
You want to run a 28" tire to keep the stability track from going off like that
flyer08 is offline   Reply With Quote
Old 08-08-2016, 02:43 AM   #14
ZL1Kid_AL
ZL1Kid_AL's Avatar
Street Rs 305/45/18
