Roto-Fab
Old 05-08-2018, 08:55 PM   #1
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
GM part numbers for rear FE4
Hello all,
What OEM parts name and number do I need at a minimum for the rear sway bar upgrade. I was thinking either the recommended ZL1 27mm bar or an aftermarket bar.
Is is just the trailing arms that I need?
  • Part Number: 92246140
  • Part: Trailing Arm
rich2342 is offline   Reply With Quote
Old 05-08-2018, 11:48 PM   #2
Avenging Orange
Avenging Orange's Avatar
Can't help you until I know what you drive. Try searching the multitude of GM part's distributors on the internet.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-09-2018, 04:26 AM   #3
rich2342
rich2342's Avatar
Apologies. 2010 ss.
Old 05-09-2018, 05:50 AM   #4
Hippy
Hotwheels
Hippy's Avatar
Drives: Hotwheels Edition
Send a message via Skype™ to Hippy
Zl1 / 1le rear sway bar setup
End links
22761221 need 2
Sway bar
22786260
2 Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
Sent from my SM-G955U using Tapatalk
Parts for Sale
2013 2SS Hot Wheels Edition 734 of 1524
Hippy is offline   Reply With Quote
Old 05-09-2018, 02:46 PM   #5
rich2342
rich2342's Avatar
Can these be driveway installed or are there special considerations or removal of parts?
Old 05-09-2018, 03:08 PM   #6
Hippy
Hotwheels
Hippy's Avatar
Depends on your macanical skills
Jackstands Will work to. Access Everythihg
Parts for Sale
Old 05-09-2018, 10:24 PM   #7
Avenging Orange
gmpartshouse.com has a zl1 rear sway bar kit for dirt cheap. Has every thing you need to convert.
Old 05-11-2018, 10:42 PM   #8
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Can do in driveway. 18mm and 21mm sockets and wrenches. Torque everything down after you put weight on the car. You will need and alignment.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 05-11-2018, 11:47 PM   #9
hammdo
'It's an experiment'
hammdo's Avatar
https://www.camaro5.com/forums/showthread.php?t=371323
https://www.camaro5.com/forums/showthread.php?t=381401
Did mine on jack stands...
-Don
747 RWHP 794 RWTQ
Old 05-12-2018, 04:16 PM   #10
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 05-12-2018, 05:02 PM   #11
rich2342
rich2342's Avatar
Trailing arms are not part of the oem upgrade, right?
Old 05-12-2018, 08:28 PM   #12
KILLER74Z28
MOD SQUAD
I believe new ones come with the 1LE conversion kit. Just normal stamped OEM parts. I installed the BMR on my Camaro.
Team LS3
Old 05-12-2018, 08:29 PM   #13
rich2342
rich2342's Avatar
Gotcha..
