09-28-2023, 10:38 AM | #1 | |
199
Drives: like a granny Join Date: Apr 2013
Stainless Power Headers installed - a mostly good value
I initially installed the Corsa mufflers on my car but did not like how deep it sounded. My ZLE's before sounded way better with Corsa. So, I decided to buy the Stainless Power headers, I come from buying ARH headers for every car and decided to cheap out. I know people rave about them but I felt they were mediocre, they get the job done but battling the exhaust leaks was a chore - ended up welding the front of the cats on, no more leaks.
The install was done on a lift and I was going to install in my garage but glad I did not. Was odd to me they wouldn't fit from the bottom but the ARH ones slide right in. The valve cover removal was easy, so no worries. Lastly I want to note that i do not have a check engine light on, so the cats work well enough to not throw a code like many others do, at least in my case. Video has comparisons of corsa and the headers, SS and ZLE, if you are interested in hearing the differences.
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon Last edited by DemonZL1; 09-28-2023 at 12:03 PM. |
09-28-2023, 12:32 PM | #2 |
Drives: 23 2SS 1LE Join Date: Feb 2019
I have never heard of anyone complaining that their muscle car exhaust sounded "too deep" but I get it. I went with AWE Touring because I wanted that deep rumble. When my warranty runs out I am tempted to get headers but I have the opposite issue where I don't want it sounding too high or raspy. Loud is fine though lol.
Good video bro!
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
09-28-2023, 06:47 PM | #3 |
Drives: 2022 SS 1LE Join Date: Apr 2022
Sounds great. I've been thinking about adding these exact headers, but was and still am a little concerned with how loud they are. I am in a tight neighborhood and don't want to piss ppl off. Not that I care, but my wife cares and the couch is not that comfy. Is there any way you can post a stealth/tour mode cold/warm start video?
I got my LT2 intake on and it is amazing. Thanks for your video. |
09-29-2023, 09:32 AM | #4 | ||
199
I am weird on the way the car sounds, once I got the ZL1 1LE sounding as good as it did, nothing could really compare. I ended with ARH Headers and cats on that car. I learned that going into the SS 1LE, I miss the sound of the ZLE because it's a higher pitched aggressive sound. The current setup on the SS is good for now. Quote:
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
09-29-2023, 08:20 PM | #5 |
That would be great.
10-01-2023, 09:31 PM | #6 | |
199
https://youtu.be/qf0MvVc61cE
10-02-2023, 11:55 AM | #7 |
Great video, however it looks like it's only about a hand full of decibels quieter. But 90 it's all that bad. Stealth mode does make the tone lower so that is a difference for the neighbors sake. Thanks for putting up this video.
I am leaning more on getting these now, but I'll have a shop install them for me. I've heard the troubles from others. The only other concern I have is, will the heat from the LT's make the starter fail quicker. But who knows, one car will die with a axle back system and another will go fully blown at 700horses and not a single issue. ha |
