Roto-Fab
Old 03-28-2013, 10:59 AM   #1
Bolt-onC6
Drives: 2017 Corvette
Z/28 vs. C7
The Z28 is hinting around 500 hp. Some say the C7 will have 500. The Z28 is going to be about 600 pounds heavier although weights have not been confirmed. If so would have to assume 1/4 mile times much better with the C7 particularly with an automatic. Track times about the same. Most likely the C7 will be in the $50K range and with all the creature comforts. Some have hinted the Z28 will be more expensive. I personally think the C7 looks better. Unless you need four seats why would anybody buy a Z28?
Bolt-onC6 is offline   Reply With Quote
Old 03-28-2013, 11:03 AM   #2
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
C7, poor mans Camaro?
GbrilliantQ is offline   Reply With Quote
Old 03-28-2013, 11:12 AM   #3
shaffe
Drives: 21 Bronco
If I was personally spending that kind of money on a car, I would rather have the Corvette.
Old 03-28-2013, 11:33 AM   #4
mechanic1
Drives: 2013 ZL1
I started to think about getting the z28 and trading the zl1..........too close to the end of the model run........although the z28 is now likely the car to collect..I hoped the zl1 would have been but I acted in haste... ...then you still have the vette to worry about.............the move here would be to get the new vette in a couple years when they put a real motor in it.......you get your decent comfort level WITH performance and wont have anything else in your class
mechanic1 is offline   Reply With Quote
Old 03-28-2013, 11:51 AM   #5
Bolt-onC6
Only problem with that is going to be price. Most won't be able to afford that new Z07 or what ever it will be called. And too it's a long wait until it comes out if you are wanting a new car now.
Old 03-28-2013, 12:00 PM   #6
Bhobbs
Bhobbs's Avatar
I would buy the Z/28 because it is an iconic car. I have always wanted a true Z/28 and this is a true Z/28.
Old 03-29-2013, 07:45 AM   #7
gmen09
gmen09's Avatar
Drives: 2010 Camaro SS ls3
Z/28 minght beat out the c7 for me purely because it is such a focused car, it is purpose built not to please a large majority, but to go fast that's it!!!
gmen09 is offline   Reply With Quote
Old 03-29-2013, 08:06 AM   #8
shawn18
OWTATIME
shawn18's Avatar
Drives: 1969 CaRaMo
I would choose the C7 in a heartbeat.
shawn18 is offline   Reply With Quote
Old 03-29-2013, 08:09 AM   #9
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
On the drag strip or road course the C7 wins hands down, the weight difference and CG difference is just too great. Folks forget the C5 Camaro is really a disguised 4 door Holden Commodore. The C6 Camaro ATS platform will be far better as it is better focused on weight as well as performance and more recent technology. What makes the C5 Camaro so popular was it's absence from 2003 to 2009 and the allowance of function follows form in the styling.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 03-29-2013, 08:10 AM   #10
IOMZL1
IOMZL1's Avatar
Drives: 2015 Z/28 | 2017 Viper ACR Extreme
First model year “base” C7 vs. ultimate Gen5 Camaro? No Contest. Z/28. There will be better Corvettes to come, as for 2014 I wouldn’t buy the C7.
dougshelbyengineering.com
www.facebook.com/dougshelbyengineering
www.instagram.com/dougshelbyengineering
IOMZL1 is offline   Reply With Quote
Old 03-29-2013, 08:10 AM   #11
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Z28 is the better car...it has the better engine and its a pure race car!!! I dont believe the LT1 will have more than the advertise estimated 450hp.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 03-29-2013, 08:11 AM   #12
Forty5th
Forty5th's Avatar
Drives: Camaro
The new for me
Forty5th is offline   Reply With Quote
Old 03-30-2013, 08:11 PM   #13
bluman
bluman's Avatar
Drives: '10 Corvette GS/'13 Mustang
I guess the Corvette is not iconic !
2010 Camaro SIM/CGM RS/2LT VIN #310 SOLD
2010 Corvette Grand Sport
bluman is offline   Reply With Quote
Old 03-30-2013, 08:21 PM   #14
360ss
ZL1 NIGHTMARES!!!
360ss's Avatar
Drives: LACS+CHEVYS
You'll just don't get it!!!
Buy what u can afford!!! Stop feeling sorry ..
13zl1 #251 NOTHING ELSE MATTER
360ss is offline   Reply With Quote
