10-21-2015, 10:51 AM | #1 |
Drives: Black 2015 2LS, Teal 1991 RS Join Date: Oct 2015
Drop in filter VS CAI
Hey guys I'm new to the 5th gen and very new to the v6 life. My other car is v8 with a list of mods but it's a different animal so I'm starting fresh here.
I've seen where with the LFX motors some guys see the same or more gain from using a drop in filter such as a K&N or Green filter to replace the stock VS using a cold air setup. Just curious on the gains (if really any) of both before I decide to start spending cash. Not looking to do a lot of mods especially because I just bought the car and also want to keep it close to stock until the warranty is up (I opted for the extended warranty). Yes I know that mods don't instantly void the warranty but I do have a '91 Camaro as the toy right now and I do a good bit of traveling and unfortunately I don't want to run too much of a risk of having to deal with a crappy dealer for service just because of a couple bolt ons. Just haven't seen any numbers on the two and I have searched for a comparison but most people seem to just switch to cold air. I like the look but I don't want to spend the $$ on a system if it doesn't give me a good enough gain on an otherwise stock setup so that's why I'm also considering a drop in "performance" filter. |
10-21-2015, 11:40 AM | #2 |
PM sent
10-21-2015, 01:17 PM | #3 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
Drop in filter will show a small gain but full intake systems can produce 15+rwhp. |
10-21-2015, 01:45 PM | #4 |
Ok so from looking at the numbers that DynoSteve sent me that all sounds about the same. I suppose I will have to just save up for a good CAI kit. I have a feeling that I am going to be as slow at modding this car or slower than I was on my '91. I don't really like doing things more than once and need to make sure I get the most for the cost of it. I'll keep my eyes out for a good kit at a good price.
Now would a catch can combined with a CAI provide a slightly larger benefit than just doing the CAI? I know that they don't essentially work together but over time the reduction of oil making it into the intake through the pcv system should allow the CAI to work more effectively longer and allow the engine to take full advantage of the larger air flow right? |
10-21-2015, 01:53 PM | #5 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
The biggest restriction is the box itself. The filter has plenty of surface area to produce good power. But you're still stuck with the factory box if you're running a factory filter.
10-21-2015, 08:05 PM | #6 | |
10-21-2015, 10:14 PM | #7 |
When you decide to start shopping for an intake you don't need to search long to find that cold air inductions is your best bet. They are the most expensive, but they are proven and tested to be well worth it. I have one in my lfx and instantly felt and heard a significant difference. It will be a mod you will not regret
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
10-21-2015, 10:22 PM | #8 |
I run 2 catch cans...
I ran a Green filter for a year before I "upgraded" to a used CAI intake. Zero difference in performance or sound; but $300 poorer. I decided to upgrade to the Apex air scoop to improve the CAI, and this did make a noticeable difference in performance, but still no sound difference.
If I was starting over, I would get the aftermarket filter, and run a hole saw into the bottom of the stock airbox and open it up, then run an air duct from the front to feed it.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
10-22-2015, 05:55 AM | #9 | |
10-22-2015, 10:33 AM | #10 |
A little faster acceleration compared to stock. I decided to install it based on tests on Vararam's website where they said that the Green filter flowed equal to the Roto-Fab intake on the V8 on their flow bench test: http://www.vararam.com/camaro-vs-comp.html
I then upgraded to the CAI based on all of the rave reviews. No difference whatsoever. Adding the air scoop definitely added more acceleration, and was the third biggest gain after the ported throttle body (#2), and Solo hi-flo cats (#1). Save the intake upgrade for the Solo hi-flo cats instead. Easily more than double the acceleration, and improves the sound tremendously.
View my top 3 LFX performance mods and more: . Last edited by yzark99; 10-22-2015 at 10:44 AM. Reason: clarity |
10-22-2015, 10:44 AM | #11 |
Well I did some looking and now I almost want to hold out for a while in hopes that Vararam makes an intake for the LFX. That thing is SWEET. And I think I read on Hawks third gen that the Vararam gurantees boosts in HP of 25 - 30. That would be one hell of a gain for an intake. Here is their link for the Vararam:
http://www.hawksthirdgenparts.com/20...uction-system/ And what would you guys think of this SLP system? Seems like it would improve airflow better than just a drop in and it's not as expensive as a full CAI setup: http://www.hawksthirdgenparts.com/co...be-and-filter/ I deal with these guys a good bit for parts for my third gen and they are one of the best places I've ever worked with for aftermarket and used parts. |
10-22-2015, 11:07 AM | #12 |
That's one of my fears on the Vararam but ya never know. But I may have to do some more research on the SLP setup I posted above. It takes advantage of the factory filter box for air but increases the amount of air supplied to the engine. Could be a very nice setup.
10-22-2015, 11:11 AM | #13 |
10-22-2015, 11:25 AM | #14 | |
