09-04-2015, 06:55 PM | #1 |
Drives: 2015_1le Join Date: Apr 2014
LS3 With No Catch Can - Long-term Results
Does anyone have the LS3 with no catch can that has higher mileage? Have you checked the intake to see if there is any build-up of gunk?
I'm asking because I have a 15 1le and I just want to keep it as stock as possible. Curious to know if frequent oil changes etc may kill the need got the catch can... Sam |
09-04-2015, 07:01 PM | #2 |
Drives: SBM G8 Gt Join Date: Jan 2014
If a catch can was needed they would have came that way from the factory
09-04-2015, 07:12 PM | #3 | |
Drives: 2013 2SS/RS LS3 - Summit White Join Date: Sep 2012
Have you seen the junk that comes out of one?
ADM Race CAI - SW LT - SW Retro Chambered 3" - EE Catch
ADM Tuned - 412RWHP/406RWTQ |
09-04-2015, 07:16 PM | #4 |
Drives: 2011 Summit White Camaro SS (LS3) Join Date: Sep 2014
Don't need one but for the cost it wouldn't hurt. I'm not going to bother.
09-04-2015, 07:21 PM | #5 |
Hotwheels
A friend had one came stock with the 2013 1le (part number turns this up) http://paceperformance.com/i-1080525...ve-system.html
But was in the truck. Dealer stated not use it on the street. Just on the track On the other hand I'm running a ls3 with a supercharger and no oil any wares but in the oil pan.. Every oil change is at the line as it was with a fresh oil change.. I change mine when the computer says it's half life (50 percent left) Sent from my SM-G920V using Tapatalk
09-04-2015, 07:27 PM | #6 |
Drives: 2012 2SS/RS M6 Join Date: Mar 2014
09-04-2015, 07:35 PM | #7 | |
Btw, my 1le did come with a box that has an oil separator in it that can be installed at some point. Just wondering to see if someone has actually put it top the test and analyzed the condition of the motor |
09-04-2015, 07:36 PM | #8 |
Mine came with one from the factory! There is a reason for them. I have an RX catch can and actually ran both, my RX and the factory one. 24/7. I ended up throwing a CEL, it turned out the factory one was sucking air and throwing the computer off because i had a leak at a connection. I now will only run the factory one when i track it. The RX will remain just as it is. There is still oil blow bye, that i empty from the catch can just driving on the street, so do what you will from real world experience.
09-04-2015, 07:59 PM | #9 | ||
Why else would GM be recalling almost 30 millions cars because of an ignition problem they knew about over 10 years ago, that some engineer probably warned them about from the beginning. Quote:
09-04-2015, 08:02 PM | #10 | |
Consistently inconsistent
Drives: 2015 2LT Summit White Join Date: May 2015
I've personally dealt with countless direct injection engines from GM and other manufacturers where we had to take it apart to remove the deposits on the backs of the valves. I had a 3.6 Equinox apart with 80K on it and the buildup was staggering... and it had scheduled maintenance.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface. |
09-04-2015, 08:04 PM | #11 | |
Drives: 2018 Audi TT RS Join Date: Jan 2014
This. I don't understand how the logic demonstrated in some of the above posts manages to perpetuate itself. In what world do you think that the engineers make the final calls as to what goes into a product for mass, manufactured production? The bean counters determine that. In the 1LE, it's standard equipment and the engine is a *gasp*, LS3. Corners are cut on almost every major component of the vehicle for the sake of cost vs safety vs longevity vs performance. The catch can is a simple, yet effective design. If you're having trouble justifying its use and purpose, I highly encourage you to research it rather than snub it.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
09-04-2015, 08:30 PM | #12 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
Here we go again!
09-04-2015, 08:38 PM | #13 |
09-04-2015, 09:23 PM | #14 |
Drives: 2011 Green SS M6 Join Date: Jun 2015
Of Course you need one---Ask the Vendors that sell them
Living dangerously without it here |
