04-06-2022, 05:58 PM | #1 |
Drives: 2015 Camaro Convertible Join Date: Jan 2015
Looking for discontinued ZL1 Rims
One of my rims ( maybe 2 ) seam to be bent because the steering wheel starts shaking at 70 mph since I already bought new tires, I might have to replace 1 or even both rims in the front.
The problem is, I can't find these 22" rims : https://drive.google.com/file/d/1tCQ...ew?usp=sharing https://drive.google.com/file/d/1tCQ...ew?usp=sharing Does somebody have an idea where to find them I think they are called ZL1 Replica.
2x 2015 Convertible 1LT
- White on Black 22”s - Silver Stock |
04-07-2022, 06:43 AM | #2 | |
Drives: 2013 ZL1 Join Date: Nov 2018
If you replaced tires the tire store "should" have let you know you had bent wheels as it is very easy to see on the balance machine. I would take it back to the tire store and tell them it has a vibration and check for bent wheels.
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
04-07-2022, 08:08 AM | #3 |
Drives: 2013 ZL1 Join Date: Sep 2021
They should be able to be straitened by a wheel shop if not to badly bent. Do you recall an incident when this happened? If it started after your new tires its likely improper balancing, a tire defect, improper/over torque of nuts or dirt/debris between the wheel and hub.
05-24-2022, 02:57 PM | #4 | |
" it's probably the tires .. buy a set of new tires an your problem will be solves .. "
