dave@hennessey
Old 10-17-2012, 09:15 PM   #1
NWSleeper
NWSleeper's Avatar
Drives: 2010 Camaro 2SS RS
ZL1 Fuel Pump in 2010 SS?
Has anyone installed the new ZL1 pump into their 2010-2012 SS? I have heard it is a simple drop in and go if you need higher fuel flow/pressure.
I have a 2010 SS with the Maggie, Kooks 17/8 long tubes and the overdrive cog. I would like to get the fuel flow up from the stock pump and the ZL1 pump looks like a cost effective approach.
Any input is greatly appreciated.
NWSleeper is offline   Reply With Quote
Old 10-17-2012, 09:24 PM   #2
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
direct replacement. just gotta drop the tank and switch it out. Looks exactly like the stock tank as well.
AngelSpeedFreak is offline   Reply With Quote
Old 10-17-2012, 09:39 PM   #3
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
I'm running one with a similar setup and have zero fuel pressure issues. Great upgrade!
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 10-17-2012, 09:41 PM   #4
NWSleeper
NWSleeper's Avatar
Do you actually have to drop the tank. Someone said that there is an access panel under the back seat that allows you to access from above without dropping the tank.
Currently I am at 505 WHP and the 52 lb injectors that came with the Maggie. I just ant to get my AFR to the high 11 maabe 12 at WOT.
Old 10-17-2012, 10:07 PM   #5
Cpanthers85
Drives: 2011 Camaro 2SS RS
Unless things have changed, the whole rear cradle has to come down to get to the tank, so
You can drop that as well. I paid 4 hours of labor for it AND they didn't charge me to do the pfadt drag 1 package since it was all coming down at the same time anyway
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 10-17-2012, 10:11 PM   #6
My next move is a fuel pump. Currently running stock with a BAP. Pressure drops to 48psi at 7.5 pounds of boost. Before I pulley down I want to make sure it's getting more fuel.
I figure a ZL1 pump AND my BAP will be good insurance.
How much is a ZL1 pump? I'll drop the tank myself.
Old 10-17-2012, 10:12 PM   #7
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
No access door.... Pumps are direct replacement and they have been used for a while now. I actually had one in my car over a year ago before you could even buy one from gm.
JLE58 is offline   Reply With Quote
Old 10-17-2012, 10:16 PM   #8
thebeast916
Drives: Blown G8 GT
Cut a hole under the rear seat pan. Takes 20 minutes. Don't drop the cradle.
thebeast916 is offline   Reply With Quote
Old 10-17-2012, 10:25 PM   #9
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Don't cut a hole in your car, drop the cradle.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 10-17-2012, 10:26 PM   #10
JLE58
Old 10-17-2012, 10:30 PM   #11
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Less than $300. I'm making 650 to the wheels with zero pressure problems.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 10-17-2012, 10:35 PM   #12
No BAP?
Do you know what your fuel pressure actually is at WOT?
Old 10-17-2012, 10:38 PM   #13
Supermaro585HP
Drives: 2011 Camaro SS RS
I just got mine a few weeks ago. I have a Edelbrock supercharger and I'm dropping down to a 3" pulley so I also got Edelbrock 60# injectors. I was told to get the ZL1 pump. I was told I should be around 540-560 RWHP. I will find out this spring.. I will not be cutting a hole in my Camaro. Holy shit!!!
Supermaro585HP is offline   Reply With Quote
Old 10-17-2012, 11:40 PM   #14
yotaman96
yotaman96's Avatar
Originally Posted by HRD_WRK View Post
If I'm dropping the cradle anyways and plan future FI, any reason I can't put the zl1 pump in now?
Would a tune have to happen if no other changes made/ gains were desired at this point?
If required, what for/what would the tuner adjust- lower voltage to the pump?
What's the max it will support -if going beyon zl1 pwr numbers?
Still learning.
Thanks
No tune needed. I don't think anyone has found the max limit yet. I have one with a BAP and its fine at 630 rwhp. Hoping for around 670 next time.
2002 Trans Am
