02-17-2011, 02:19 PM | #1 |
Auto body and paint guy
Drives: 2010 Camaro LS Join Date: Feb 2011
removing front seat
anyone know how to remove the front passenger seat, or have a write up of how to do it? i have a idea.. but now a 100% sure.
02-17-2011, 03:14 PM | #2 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
there are a couple of threads on the first two pages of this section that go into detail.
I actually JUST finished removing the bolts so that i can take my seats out and work on them. if you move the seats all the way forward, take a look on the railing behind the seats, where the seats are attached to the floor. there is a bolt on each railing that attaches the railing to the floor of the car. take those off and then the lift up and move the seats and the railing back so that they unhook from the front. that's it. don't forget to remove the connectors for the wires (i didn't get that far yet). i wish you luck, i started doing it yesterday but had to stop because those bolts on the railings have locktie on them and they are FREAKING tough to get out. i had to get a big torque wrench and a long extension so that i could get good leverage to remove the bots. the size of the bolt is a 50 size torx. |
02-12-2014, 03:19 PM | #3 |
Drives: 2011 Camaro 2SS/RS Vert Join Date: Jul 2011
Sorry to bring this back...
I was a little too excited trying to get the bolts out and stripped one.... How do I get it out????? Ive tried many different things and nothing its pretty bad also......
02-14-2014, 11:54 AM | #4 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Oh,oh, how did you "strip it" removing? I used an air wrench. Does it just spin around?
02-14-2014, 04:50 PM | #5 |
So I am condfused about removing the front seats.. Yes I did a search... Everythings just says to remove the back bolts, but I can't get them to come out. With a little muscle I loosened them up and unscrewed them most of the way, but once I get to the point that I think they are about to come out they get so tight I can't turn them anymore. Is there a nut or something under the floor panel? and if so how do I get the bolt to come off? Just more muscle cause it gets really tight almost like I'm tightening it down.
02-14-2014, 07:50 PM | #6 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
There is lock-tite on them and yes they get tougher just before they finally come out. Tighten them, loosen them tighten them, back and forth and it will go a little farther each time, you are essentially removing the lock-tite.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
09-30-2014, 10:17 PM | #7 |
Drives: 2014 camaro ss/rs 6.2L with a 3.91 Join Date: Sep 2014
Quick question I was going to remove my front passenger seat and I got the bold half way out before I realized there seems to b a free floating wing nut that will drop if I remove the bolt all the way and there is no access hole under the car. Do I need to cut a hole to access the nuts
10-01-2014, 08:22 AM | #8 | |
Drives: 16 Camaro SS Join Date: Jul 2012
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
03-23-2019, 01:25 PM | #9 |
2015#1178 Red/AC/Speakers
Drives: 2015 Chevrolet Camaro Z/28 Join Date: Mar 2019
The seat track screws on the back are T50 Torx socket head on my '15 Z/28. If you crank the seat all the way up and forward, you can get a 1/2 drive with some extensions straight on it, or even use a wobble extension if you want. I put some WD40 to keep the Locktite from binding and potentially stripping the head out. I worked them out a bit with a 1/2" drive ratchet, back in, and you could feel them loosen up. Hit each with the impact and they came out nice. Pull the ribbed button on the end of the connector to unlock it and disconnect by pulling it apart as illustrated in this thread https://www.camaro5.com/forums/showthread.php?t=100176 . Remember to crank the seat back down before removing it and put something on your door sill to prevent the seat tracks from scratching it when you take it out.
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
FS: Factory Cloth Seat Covers - Front and Back | Red67Stang | Interior Parts & Accessories | 6 | 01-08-2011 09:46 PM |
Fitting a baby seat in the back of the Camaro | monstertodd | 5th Gen Camaro SS LS LT General Discussions | 14 | 07-06-2010 08:41 AM |
Removing the front Bowtie | chevyridinghigh | Cosmetics and Lighting Modification Discussions | 8 | 06-23-2010 07:58 PM |
No confirmation number? | jamesc1123 | Camaro Price | Ordering | Tracking | Dealers Discussions | 12 | 02-21-2009 08:49 PM |
