dave@hennessey
Old 02-13-2014, 09:52 PM   #15
layzurguy
Ride On!!!!
layzurguy's Avatar
Drives: 2012 SS Ragtop
Originally Posted by Chevrolet Customer Svc View Post
I apologize to hear about your vehicle concerns and service experience. Thanks for the update and feel free to contact us privately if there any lingering concerns that require additional assistance.
Sincerely,
William R.
Chevrolet Customer Care
layzurguy is offline   Reply With Quote
Old 02-14-2014, 03:39 PM   #16
imnuts
imnuts's Avatar
Drives: 2011 2SS/RS convertible
Originally Posted by Jfoster View Post
I'm not sure they would have to even touch the cable tensioners to replace the 5th bow, but if they do they should still be snug along the edges just above the door windows and from previous posts the cable should not be visible, especially by the side rear windows. ToddB would know for sure, being he's replaced his.
On the cable tensioners, you can slid your finders just under the edge of the seam and they should be snug. If they're broken or not routed correctly you'll be able to easily slid you fingers under the edges. You would also notice windnoise with air getting under it, similar to having the window cracked open.
Attachment 599628
Attachment 599629
is this something we can tighten on our own or should it go to the dealer?
reason I ask this is because my passengers side is not tight at all and yes it sounds like the window is cracked open.
thanks for any info I can get on this
Rob
imnuts is offline   Reply With Quote
Old 02-14-2014, 06:41 PM   #17
Jfoster
Drives: 2016 GT vert.
Rob
Fwiw, that was the same side as mine. I had the dealer repair mine. He had to replace the whole cable on mine. I'm not sure what all it involved, it was in the shop for two or three days.
Jfoster is offline   Reply With Quote
Old 02-14-2014, 09:19 PM   #18
imnuts
imnuts's Avatar
I just had a look at my top. on the drivers side there is a small steel cable passing through the rubber weatherstrip and connected to the top just above the rear quarter window. Nothing like that on the passengers side. I'm thinking that maybe the problem.
Old 02-16-2014, 08:04 PM   #19
2011*Camaro*SS
2011*Camaro*SS's Avatar
Drives: 2011 Camaro 2SS/RS Vert
Sincerely,
William R.
Thanks William, Ill keep you updated!
2011*Camaro*SS is offline   Reply With Quote
Old 02-18-2014, 08:58 PM   #20
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
No problem,
Looking forward to it .
William R.
Chevrolet Customer Svc is offline   Reply With Quote
Old 02-18-2014, 10:33 PM   #21
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
William, thanks for taking the time to check in and help us here as needed.
OrangeVert is offline   Reply With Quote
Old 02-19-2014, 11:53 AM   #22
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
If you see the metal cable along either side of a replaced top, it was routed incorrectly. It needs to go back and redone the correct way. If not, you will have nothing but problems moving forward. Take it from someone that has been there already.
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 02-19-2014, 05:53 PM   #23
Drives: GM Vehicles
You are absolutely welcome. Here to help as much as possible.
William R.
