TireRack
Old 07-01-2014, 10:06 AM   #1
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
Top Speed for 500RWHP
Just curious what the top speed for our car would be if it was making that much HP to the wheel. I could of sworn I saw a post a while backing saying how much HP was needed to achieve certain speeds, can't seem to find it now though
FaytalsCamaro is offline   Reply With Quote
Old 07-01-2014, 10:16 AM   #2
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
I'm curious, too.
E.T. is offline   Reply With Quote
Old 07-01-2014, 12:24 PM   #3
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
If aero stability holds , you would probably see 200mph is my guess.
amz is offline   Reply With Quote
Old 07-01-2014, 12:42 PM   #4
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
I've not seen the post you're referring to but I would think top speed would vary depending on local weather conditions, if it's hot and humid you will lose some of that power. Also, if you have changed your rear gear ratio your overall top speed can be different from stock. Best way to find your top speed would be to get onto a private strip and go for it
Sent from my iPad using Tapatalk
RolltideSS is offline   Reply With Quote
Old 07-01-2014, 12:50 PM   #5
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
I can get pretty close if I have HP, rpm for HP, torque, rpm for torque, axle gearing, and transmission. It doesn't even take very long.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-01-2014, 03:05 PM   #6
FaytalsCamaro
hmmm...well if the climate was perfect and you had a lower gear ratio than the 3.45...you think 200mph would be possible in a camaro SS with 500 to the wheel?
Old 07-01-2014, 03:20 PM   #7
ChrisBlair
Buick 455 Fan
If it's drag limited, I have read the CoD is .35 for a coupe. We'd need to know the frontal area of the car. This thread discusses it:
http://www.camaro5.com/forums/showthread.php?t=6767
If it's gear limited, well, I did a chart on that but only to 150mph:
http://www.camaro5.com/forums/showthread.php?t=357518
But that could be extrapolated out. The gear ratios are listed on my chart
Old 07-01-2014, 03:38 PM   #8
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I think if you took a stock SS and (somehow) made it pull 500 RWHP, top speed would be the same. The speed limitation would still be, what, 155? Not trying to be a smart ass, but it would take more than just 500 rwhp to increase the top speed. Now, you'd get to that speed sooner, but still... It would depend on the tune, the rear end gearing, etc.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 07-01-2014, 03:40 PM   #9
I know some magazine tuned a stock ls3 or l99, can't remember, and ran up to 173-174, everything else being stock. so I would think putting 500hp to the wheels would get you to 200 pretty easily.
Old 07-01-2014, 03:43 PM   #10
FaytalsCamaro
My apologies, I should have stated without the speed limiter in place
Old 07-01-2014, 03:43 PM   #11
although, I remember reading somewhere that the zl1 top speed was 184. not sure if it was because of a limiter, or just the top speed.
Old 07-01-2014, 03:45 PM   #12
FaytalsCamaro
I remember hearing that too, I also dont think that it HAS a speed limiter. Should also realize that it is what...300lbs heavier. Although I dont know if that even matters at those speeds
Old 07-01-2014, 03:48 PM   #13
found the article:
http://www.popularmechanics.com/cars...o-bonneville-2
it was an ls3.
Old 07-01-2014, 04:45 PM   #14
bdrobLS3
bdrobLS3's Avatar
Drives: 2012 Camaro 2SSRS Manual Coupe
Send a message via AIM to bdrobLS3
I have a few more ponies than 500 but i've hit 187 in 5th gear at the just before redline and 6th just feels like you deployed a parachute. so / 186??
bdrobLS3 is offline   Reply With Quote
