07-14-2010, 09:48 AM | #1 |
Drives: Camaro SS Join Date: Dec 2009
Methanol Question
I have a windshield washer liquid from Cyclo that has 98% Methyl alcohol (Methanol) will it work fine to kill detonation and add more octane when spray it after the MAF? Do I need to mix water with this formula?
Will it require a tune? I have been told that it makes the car rich Thanks, |
07-14-2010, 10:31 AM | #2 | |
Usually Only Supercharged cars Respond to Methanol injection due to high charge temps. Ted.
www.jannettyracing.com
07-14-2010, 11:10 AM | #3 |
Well, I have a friend who does not have 93 fuel in his area, so will this work for him?
07-14-2010, 11:11 AM | #4 |
Drives: 2006 Corvette Z06 Join Date: Feb 2010
If you have a bolt-on, NA setup... you're not really going to gain much if anything from spraying meth. Run a good AFR (12.4-12.5 at WOT) to quench the charge, and you'll be fine.
As stated above, forced induction is where meth is most valuable. It can also be good on high compression nitrous setups. |
07-14-2010, 12:00 PM | #5 | |
07-14-2010, 12:05 PM | #6 |
I found this article and I want to share it with you guys
Why Water Methanol Injection? In gasoline engines, as with any intercooler, this suppresses detonation so more power producing boost and timing can be utilized. Water, with its high latent heat of vaporization cools the intake charge and combustion. Methanol cools the charge and combustion but also acts like an extremely high octane fuel (some researchers claim as high as 120 octane) as well as adding more oxygen to combustion. In recent years, water methanol injection has become ever more popular and recognized as an invaluable tool for both gasoline and diesel forced induction engines as well as naturally aspirated applications. While often times referred to as a “chemical intercooler” it is more commonly used in forced induction applications due to it’s substantial cooling effects and added octane increase it adds to pump gas. Reducing air intake charge temperatures by 50-200+ degrees F almost instantly. Providing a substantially cooler denser air charge for a greater expansion of power within the combustion chamber. While also largely eliminating the problem of engine “knocking” and allowing user to run higher levels of boost, compression and increased timing. As mentioned already. Water methanol injection has also become a tried-and-true proven way for users to effectively increase their 87-93 octane pump gas. Depending on the amount injected, gains up to 10-20+ points in octane can be achieved. Thus, making 91 octane pump gas act like 105-116 octane racing fuel in their engines. Thereby eliminating our dependency for notoriously expensive racing fuels, which can cost upwards of $8.00-$12.00 per gallon, as so many of us have reluctantly had to use in the past. Costing only pennies to operate when using 100% water, its also a far more effective, affordable and convenient of a solution to those expensive octane booster fuel additives as well. What types of fluids can I use? Water and various grains of alcohol, methanol, ethanol and isopropanol, are the primary fluids which are commonly used in a water alcohol injection systems. Depending on the application, we have found mixtures of 40/60 water and methanol to perform the best without the risk of being a flammable fluid. This surprises many the first time they hear it. When injected properly into the air charge of an engine, water and water alone, is a remarkable detonation suppressant. The most notable advantages of using water injection is it's inability to detonate as well as it's substantial cooling effect it has on air charge temperatures, combustion temperatures and exhaust gas temperatures. Best of all...it's basically free. Water has a high latent heat of vaporization. Approximately, 8 times that of gasoline and can reduce intake charge temperatures by 50-150+ degrees F on supercharged and turbocharged engines almost instantly when sprayed properly. It’s also an extremely effective octane booster. Since water does not burn “per‘ say, when atomized properly with pump gas, it will effectively increase the fuels octane. Doing so, by improving the fuels ability to resist self-ignition under higher cylinder pressures and hotter cylinder temperatures thus suppressing detonation. The easiest fluid to use is a non detergent blue windshield washer fluid…this will contain water and methanol! Through testing and research, comparing high-octane fuels vs. 87-93 octane pump gas combined with 100% water injection (no alcohol mix added). Depending on the build of the motor and volume injected, it is estimated octane increases of 10-20+ points can be achieved by using 100% water injection with 87-93 octane gas. This is after evaluating maximum allowable total timing advance and maximum attainable boost levels with out detonation or pre-ignition. Benefits of Water Alcohol/Methanol Injection on NA application: Lower air charge temperatures by 30-40 degree's Reduces cylinder temperatures by 200+ degrees Increase your 87-93 pump gas by 10-15+ points Allows the use of lower grades fuels Allows you to safely run more timing Cools and protects the tops of your pistons Longer more stable combustion expansion and progression Removes carbon build up from combustion chambers, pistons and valves Reduces & helps eliminate damaging engine detonation & pre-ignition No need for expensive racing fuel or additives |
07-14-2010, 12:14 PM | #7 | |
If you want to clean your pistons, just spray nitrous. Done. |
07-14-2010, 12:40 PM | #8 | |
Drives: 2010 Camaro Auto Join Date: Mar 2010
07-14-2010, 01:01 PM | #9 | |
07-14-2010, 01:05 PM | #10 |
We can not deny the benefits of spraying Meth but as Dsteck stated I am not going to notice that much difference..!!
07-14-2010, 03:06 PM | #11 |
Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
07-14-2010, 04:52 PM | #12 | |
Cyclo® 100% Concentrate Windshield Washer 90-100% methanol MSDS http://www.cyclo.com/system/images/msds/C207.pdf well adding meth inj to my car but it is supercharged. On NA your not going to gain much to make it worth while. Add a supercharger then you got reason to install meth inj
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
06-29-2011, 04:06 PM | #13 |
Drives: 2010 Camaro Join Date: Jun 2011
rr
07-05-2011, 07:48 PM | #14 | |
Drives: 1999 500 HP Corvette Join Date: Jan 2010
The findings lead to water/meth being used in like fighter planes. Their testing and many others like I have done found the same answer and that is BEST case is 50/50% ratio mix Using more meth then that only can quench the cylinder and slow the burn rate down Most cases people use winter version of windshield washer fluid. -20 deg WW fluid has 38% meth, it is cheap as places like Walmart sell a gallon for under $2. Pulling straight meth is about $4-5 a gallon and feds think people can make bombs from it so if buying from a vendor not local expect to pay much more for a hazard shipping cost. Most of us use the WW tank and have it clean windshield ( even if using 50/50 % ratio) and another hose to feed the water/meth pump. I have been doing this since mid 1970s when the first oil scam job occurred in my 1974 Corvette and every one since and they ALL have been NA engines. With higher engine compressions, lousy gas with ethanol in it using water/meth is not just what performance gains you can get but also preventing performance loss as lousy gas, hot weather, etc causes PCM to detune engine and to yank lots of timing during engine knock Every time PCM pulls timing then the engine has to recover between high and low octane (knock) tables which is a killer such as being at a drag strip Using water/meth cares if engine is NA or boost as it's purpose is to 1. pulls out about 40 degrees of heat from intake air 2. methanol hitting cylinders gives a cleaner, better burning charge. 3. prevents knock 4. cleans carbon off pistons and valves. 5. increases the octane level 6. prevents timing loss that also reduces torque 7. with little or no knock with water/meth with a good tune allows more timing which increases engine output 8. helps make up for the lousy ethanol gas. Feds just approved that 15% ( E15) can be sold, the more ethanol in gas the less performance, mileage, leaner fuel trims, more engine knock and the water/meth helps make up for those losses and issues. 9. Since methanol and colder air in cylinders cools the charge down then the AFR is richer thus takes load off the fuel injectors, or allows injectors that were over a 80% duty cycle to be reduced so that a bit larger injectors are not needed My 1999 NA LS1 C5 at 500 HP has used water/meth for 10 years with zero long term issues. Even when injecting 200 HP shot N20 have used water/meth at the same time with no ills. Inspection of pistons and valves have no carbon build up as the build up increases of carbon also then increases cylinder compression which induces more engine knock. Finally back in mid 1970s even GM had a few car models that came with water/meth with NA engines. Problem was car owners did not understand water/meth and would never fill the water/meth tanks Today with the electronics even WW tanks with low fluid volume sensors it is simple to use water/meth on a daily basis |
Similar Threads | ||||
Pics of our Coolingmist Methanol system install on street brawler package | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 73 | 11-29-2011 10:09 AM |
Custom wheel offset question ... | Bowtie Junkman | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 04-23-2010 05:16 PM |
aquamist vs snow (methanol kits) | Carlos Garza | Forced Induction - V8 | 23 | 03-22-2010 09:18 AM |
Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 06:53 AM |
Question re: c.i. displacement and hp | Arli | 5th Gen Camaro SS LS LT General Discussions | 6 | 03-24-2009 01:20 PM |
