Old 03-26-2017, 08:20 AM   #1
catdog
Drives: 2017 Camaro ZL1 M6 pdr roof CF blk
New ZL-1 Convertible Review
http://www.caranddriver.com/reviews/...t-drive-review
2017 Chevrolet Camaro ZL1 Convertible
An American bad-ass goes topless.
Have you ever wanted to pilot your very own F/A-18 Super Hornet fighter aircraft? The multirole jet boasts insane speed, precision handling, and a price tag that only professional baseball pitchers could afford. For a starting price of $69,435, Chevrolet has a much more affordable alternative: the 2017 Chevrolet Camaro ZL1 convertible, an open-air rocket ship capable of serious speed and eye-popping handling, without the need for a pilot’s license, security clearance, or a Major League contract.
Too Cool
Powering the Camaro ZL1 is General Motors’ LT4 supercharged V-8, delivering 650 horsepower and 650 lb-ft of neck-straining torque. To keep this nuclear reactor of a drivetrain from having a meltdown, Camaro engineers incorporate 11 heat exchangers, sticking them into any orifice that air passes through to keep the various fluids from overheating. Torque is routed through a standard six-speed manual transmission or the all-new optional 10-speed automatic.
The six-speed manual gearbox is controlled via a well-weighted, suede-wrapped shifter that travels through its gates with precision. Clutch effort is surprisingly low for an engine capable of so much thrust, and the clutch-pedal feedback leaves no question of when engagement is going to occur. A no-lift-shift feature makes aggressive gearchanges a breeze, and selectable automatically rev-matched downshifts bark an authoritative tone from the dual-mode exhaust.
The ZL1 is the first recipient of GM’s 10-speed automatic, denoted as the Hydra-Matic 10R90. This $1595 option was co-developed with Ford, but the Blue Oval gearbox is coded 10R80. To handle the ZL1’s torque, Chevrolet engineers use more robust clutches, planetary carriers, and output gears. Other changes include the use of a different torque converter and shift-control software, the latter of which is something special. The gearchanges around town go virtually unnoticed, and the hunt for the right ratio always bags a trophy. An impressive 10th-to-third-gear downshift occurs when the throttle is mashed while cruising at 60 mph or so, rocketing the Camaro up to carrier-takeoff speeds in little more than an instant. Although manually shifting gears is an option, shuffling through 10 speeds is a task more exhausting than rewarding. If dictating ratios is your thing, stick with the standard six-speed ’box.
Pop the Top
The ZL1 shares its folding roof hardware with its lesser-powered Camaro siblings. The top can be lowered or raised in 13 seconds and at speeds up to 30 mph, Chevy claims. The Camaro is well known for providing a claustrophobic, periscope-like outward view, but lowering the roof means the massive rear pillars disappear and the blind spots are no longer a factor. However, with the top up, rear visibility is even further restricted than in the coupe, as the rear window in the fabric top is basically a slit. At highway speeds with the roof lowered, wind buffeting and noise are noticeable but acceptably low. Run the speedometer into triple-digit speeds—easy with this much power—and, as you might suspect, the wind becomes very obtrusive.
Selecting the topless ZL1 tames the track-day specialist coupe by stripping away some of the high-tech hardware, creating more of a formidable Sunday cruiser. The convertible lives without the coupe’s trick eLSD, or electronically controlled limited-slip differential. The folding roof hardware gobbles up the available space, so a conventional limited-slip diff is installed instead. More important, this in turn takes away Chevrolet’s stellar Performance Traction Management (PTM) feature, a multilevel stability- and traction-control system capable of turning any driving zero into a road-course hero. While launch control is still selectable, the loss of PTM means there’s no longer the ability to customize launches by dialing in wheelspin off the line. Chevrolet engineers are reluctant to use the word softer, instead describing the adjustments to the magnetorheological dampers and electronically assisted steering as “expanding the bandwidth” when in Tour mode. Smaller-diameter anti-roll bars are used in both the front and rear to dial back some of the athleticism. Even with the, ahem, expanded programming, the ride is compliant and the lighter steering remains sharp.
Our 250-mile drive involved divided highways and interstates, not the best roads to accurately assess the ZL1 chassis with its upper structure removed. However, the ability to drive the coupe back to back with the convertible did provide some insight; it’s immediately apparent how stout the Alpha architecture is with a metal roof. While the convertible’s structure is solid, the lazier dampers may mask some of the impacts sent through the chassis, which seemed notably flexible in our initial Camaro convertible drive. Over undulating surfaces, a slight shake can be felt through the steering wheel. One attribute shared by both body styles: Stomp on the throttle in a straight line and the ZL1 feels like it’s being shot off a flight deck.
The Camaro ZL1 convertible offers mind-bending power and hair-removing speeds, and it seems destined to dethrone its kin, the Camaro SS convertible, as the quickest droptop pony car we’ve ever tested, once we get one to the track. And it offers something that Dodge Challenger SRT Hellcat and Ford Mustang Shelby GT350 owners are missing out on: an out-of-doors experience. Selecting an open-air cockpit may dilute the performance, but it certainly doesn’t diminish the fun.
catdog is offline   Reply With Quote
Old 03-26-2017, 11:29 AM   #2
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
Great review, but did you read the comments. Lol, what a bunch of idiots that really don't know crap about the ZL1.
KLR ZL1 is offline   Reply With Quote
Old 03-26-2017, 11:38 AM   #3
catdog
Completely agree about the idiotic comments.
You've got the guy comparing the GT3 to a convertible and so on and so forth.
I have a 991 Carrera 2S and even though it's fun to drive and awesome it is completely different experience and it does not scratch the same itch as the V8 LT1 in my recently traded-in 2017 2SS. That V8 with the NPP and the whole shifting/sound/immediate torque etc. is unique.
So, hoping my incoming ZL1 turns that to "11"... throw in supercharger whine as cherry on top...
Old 03-26-2017, 11:52 AM   #4
snackbar64
snackbar64's Avatar
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR,
Less really isn't more here, except for the price. This is why having a sunroof made more sense to me and was the route I went. You can get an open air experience somewhat, while maintaining all of the performance goodies. I can't fathom spending more for a car with so much less (Even though I don't intend to race it), but I bet they'll sell a ton of them. It is undeniably a beautiful car in this trim, but just wasn't for me. Bring back the T-Top and everyone wins!
snackbar64 is offline   Reply With Quote
Old 03-26-2017, 12:09 PM   #5
MoreSpeed
MoreSpeed's Avatar
Drives: 2017 Hyper Blue A10 ZL1
Yes. I have had the 997 Cab and have the GT3 997.2. My ZL1 would smoke both of them... especially the Cab. That Cab was a soft car and almost 2x the ZL1 price. It is interesting hearing these aguements when the person dissing probably has not experienced any of the cars discussed and drives his mom's Saturn when given a chance.
The bicycle comments were the real point of reference.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 03-26-2017, 01:09 PM   #6
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
Nice review! Question...will we really miss the PTM in the vert? We won't be tracking this car and there will often be 3 of us in it. Does PTM really only come into play on the track?
ScottMZ3 is offline   Reply With Quote
Old 03-26-2017, 01:17 PM   #7
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
Um, what option is this?
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 03-26-2017, 01:39 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Carbon Fiber Dash insert? Delayed release...should be available MY 2018.
Old 03-26-2017, 01:56 PM   #9
cleoent
cleoent's Avatar
That looks sooooooo good.
Leo
2016 e-Force 2SS
Instagram @cleoent
Old 03-28-2017, 10:51 AM   #10
fastball
Drives: 2017 Camaro 2SS 6MT
Have you read many of the comments in their reviews over the last couple of years? They're stuck in 2000 and still think all American cars are garbage and all German and Japanese cars are the best.
fastball is offline   Reply With Quote
Old 04-01-2017, 07:49 PM   #11
1BlinkGone
Drives: Any
Welcome to the hive-mind of C&D.
1BlinkGone is offline   Reply With Quote
Old 04-04-2017, 11:36 AM   #12
SoCal Racer
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1
Are they still intending on making that Carbon fiber dash? my order got delayed orignally because this was on my order sheet. I eventually gave up, thankfully...or I still would not have my ZL1...
Hope to see it...and hope I will be able to buy it after the fact so I can replace the suede insert
SoCal Racer is offline   Reply With Quote
Old 04-04-2017, 11:42 AM   #13
fastball
That carbon fiber is tight! Completes the dashboard. Technically most every other performance car you can think of offers carbon fiber trim either optional or standard. I would LOVE to buy this and install it on my car.
Old 04-04-2017, 11:45 AM   #14
Mr. Wyndham
I think so.
