10-28-2011, 10:31 AM | #1 |
87 vs 93 fuel
I have a friend that says i should be running premium fuel on my v6 camaro because of its high compression (11-1) but ive been running on regular and have not had any problems what do you guys think?
10-28-2011, 11:30 AM | #2 | |
Ted.
www.jannettyracing.com
10-28-2011, 11:45 AM | #3 |
Ok That sounds about right thanks alot
10-31-2011, 10:35 PM | #4 |
Ok so i tested the 87 fuel vs the 93 fuel and did not feel much of a difference so i think i will stick with 87 for now
10-31-2011, 11:10 PM | #5 |
Drives: 1999 500 HP Corvette Join Date: Jan 2010
You need to be more concerned on how much ethanol % is in gas.
Damn feds approved cars newer then 2000 for E15 or 15% ethanol. More ethanol % the leaner engine will be running, the fuel mileage also drops and so does the performance. Takes only a few minutes to test gas for ethanol so if in doubt test and also query gas stations used and require they know how much ethanol is in their gas. |
11-01-2011, 07:16 AM | #6 | |
GM has done a great job at making the changes seemless. Ted.
Similar Threads | ||||
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles | steeleshark2 | Tuning / Diagnostics -- engine and transmission | 11 | 04-08-2020 10:49 PM |
E85 TUNE RESULT!! | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 327 | 10-13-2011 06:22 PM |
** Fore Precision Dual & Triple Billet fuel pump assembly ** | IPS Brandon | Engine Internals | 0 | 03-11-2011 01:28 PM |
Nitrous System ?????s | PoleCat2SSRS2010 | Forced Induction - V8 | 29 | 12-08-2010 05:55 PM |
