11-01-2011, 02:52 PM | #29 |
I know it's not the easiest thing in the world to do but... Is it possible to swap O2's (B1,B2) and see if CEL changes to P0171 (lean B1)?
11-01-2011, 03:00 PM | #30 | |
Drives: 1999 500 HP Corvette Join Date: Jan 2010
If long terms are that high but short terms are not suspect a gas issue. Reason GM and other nameplates refused to agree with the feds on the new E15 and GM says they cannot warranty for. Worse for older cars like C5 Corvettes, Camaro, etc as PCM gets into a wacked state as no software in PCM can revert from a high +25% due to high ethanol percent and simple tests of gas by owners can assure what percent is really in their cars Not the best example but good enough to see this Camaro putting out 550 HP ( boosted) you see almost no engine knock yet one side reporting as much as 20% lean and other side not as lean long term but short time fuel trims nuts on. |
11-01-2011, 03:23 PM | #31 |
US Army Retired
Drives: IOM 2SS-RS - A6 (L99) Join Date: Aug 2009
What type of air filter do you have? Oiled filters that leak just a little oil on the MAF could also give off this code. I had this issue on my truck. I cleaned the MAF and went to an unoiled filter and had no more issues.
SMKIN SS
11-01-2011, 03:27 PM | #32 |
Drives: '69 SS Convertible Join Date: May 2009
Ok....I'll try to take a look at the 02 sensor again.
My car has just over 9k so mileage isn't that bad. Headers are KOOKS brand so I hope there wouldn't be any leaks but you never know. Again I'm more skeptical in my situation of something with the 02 since I went basically 6k with the header install/tune without issues. Then seeing this issue shortly after removal/reinstall of exhaust.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
11-01-2011, 07:39 PM | #33 |
Drives: 2010 2SS Join Date: Apr 2010
11-01-2011, 08:43 PM | #34 | |
So a BxS1 cannot be swapped with a BxS2 In any case if swapping position but best case is then to reset the PCM so all long term averages are erased and then you would see results of swap quickly and PCM would do new 02 tests. Being tests are done on cold starts best to monitor then to see how all 4 02s are functioning as a weak or dirty may look OK once they are hot but are out of range when they are cold |
11-01-2011, 09:14 PM | #35 |
Yes. Swap B1S1 (Os sensor drivers side before cat.) with B2S1 (O2 sensor pass. side before cat.). Clear CEL and test drive for as long as it has taken for it to come on the past couple of times you cleared and got this same code. If P0174 re-occures, the O2 is not the culprit and replacing it would be a waste of money. If P0171 is shown, then it is definetly an O2 problem.
11-02-2011, 10:57 PM | #36 |
Ok....so here is an update. First off I thought my installer got rid of my rear cats with header install. Not the case though.....I still have both front and rear 02 sensors. Looking back on when the exhaust was taken out for my bushings it had to have been the rear 02 sensors that were hanging down since the front sensors are in the header collector and we didn't touch the headers. We only removed the exhaust from right after the headers.
However, based on the fact that the rear 02 sensors should have been tuned out with the tune for the headers I focused on the front 02 sensors. I was a little concerned since those sensors have never been taken off since the header install. For troubleshooting purposes though I decide to switch the driver side and passenger side front sensors. After completely unplugging and swapping the two sensors, then zip tieing them out of the way.....started up the car and CEL instantly went away. I'm kinda shocked that the CEL cleared itself and did it immediately. I would've thought it would take a couple engine starts to run through the tests again. I've only driven it for 10 min from my dad's shop to my house but I started it at least 4 times after the sensor swap and no CEL. I'm keeping my fingers crossed it stays that way.
Build Journal |
11-03-2011, 02:10 AM | #37 | |
Drives: 2010 2SS/RS IOM M6 Join Date: May 2011
Whipple 2.9L S/C, ARH LT's, Flowmaster AMT, HPTuners
11-03-2011, 08:26 AM | #38 | |
Ted.
www.jannettyracing.com
12-06-2011, 01:29 PM | #39 | |
Well, unfortunately a couple weeks later (which was last week) it came on again. This time it's saying both P0174 and P0171....bank 1 and bank 2 are too lean. Wierd thing is that it came on last Thursday but didn't have time to go read it because I was going out of town Friday. I got back on Sunday (two days ago) and just got the chance to drive it today but my wife drove the car yesterday. I had to run an errand this afternoon and while I was out I was going to run by AutoZone to read the CEL. On my initial drive to my first errand the CEL was still there but after I was about to go to AutoZone the CEL went away. I still went to read what the CEL was and thats where I saw the 174 and 171 code. Now I'm wondering if my tune is just off. I've only added a ported TB and the ADM scoop since it was initially tuned my ADM. Neither is supposed to require a re-tune. In addition I've had both those mods on for quite a while (several months) before I started this CEL issue. I guess I'm going to start researching more about the SCT tunner and I'll probably be emailing Ted about my tuning options with him. I was hoping to not have to spend another $400 out of my mod fund but I guess I may have no other real option.
Build Journal |
12-06-2011, 03:10 PM | #40 | |
I look forward to working with you. Ted.
12-06-2011, 03:15 PM | #41 | |
Stupid CEL came on again so it didn't even last 15 miles this time.
Build Journal |
12-14-2011, 01:11 AM | #42 |
Drives: 2016 Camaro 1SS A8, 1998 K1500 5spd Join Date: Aug 2010
i would become good friends with someone that works at a shop with a smoke machine...stuff a plug in the throttle body and one tail pipe, and shoot some smoke in the other tailpipe to make absolutely sure there are no exhaust leaks
if you can get your hands on a smoke machine i would also use it to check for vacuum leaks...who knows, maybe the lean code showing up after the exhaust was removed was a coincidence...i've seen wierder things happen haha another thing to try is you can unplug the maf to force it into Speed/Density mode, you could watch your fuel trims and see if they go back to normal, normal fuel trims in SD mode = faulty maf sensor, or it may be dirty/contaminated with oil as previously mentioned. i hope this helps you out. good luck fixing the problem man, i'm curious to see what's causing this
*2016 1SS A8-12.100 @115 Bone Stock.
11.54 @116 with cat delete, converter and dr's Previous Rides 2010 Camaro 1SS M6-12.14 @114 Bolt Ons 2014 GMC Sierra SLT 5.3/6L80 |
Similar Threads | ||||
One possible solution to CEL P0430 w/ JBA midpipes | Goliath | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 01-10-2011 07:55 PM |
Advanced Auto Parts online coupon code | crzycicada | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 0 | 12-17-2010 09:57 AM |
Did you get an "EVENT HISTORY" for YOUR car? | CamaroScotty | Camaro Price | Ordering | Tracking | Dealers Discussions | 24 | 11-21-2010 11:20 AM |
Another LT Headers and CEL for Emissions | kauffjd3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 10-29-2010 02:54 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
