07-07-2016, 10:17 PM | #1 |
Drives: 2015 2SS RS 1LE Join Date: Nov 2015
Abnormal Rear Tire Wear 15' 1LE
Quick question. This car has 4000 miles on stock Goodyear Supercars. Car is a 1LE sold as certified pre-owned. What do the experts think about the wear on inside of rear tires? Although not pictured, both rears are about equal. This shot isn't the best but I will post better ones soon. They show a side by side comparison with the front tire. Right edge in pic is what I'm referring to. Rear tire is on the right. Is increased wear on the inside edges of the rears a sign of a bad alignment on a new car? Or is it typical of lots of burnouts? Or something else?
Sent from my iPhone using Tapatalk Last edited by Mach83; 07-07-2016 at 10:32 PM. |
07-07-2016, 10:38 PM | #2 |
Here are some more shots of both rear tires.
Sent from my iPhone using Tapatalk |
07-08-2016, 04:25 AM | #3 |
Drives: 2015 Chevy Camaro 1LE Join Date: May 2016
I had the same issue with my 15 1LE. I just thought it was from burnouts but idk. My fronts still look in great shape but the back are gone but the wear is the same wear pattern as yours
07-08-2016, 05:30 AM | #4 |
I had same problem with front and rear. The rear tires wore on inside front on outside.Went and got 4 wheel alignment. Six k later all looking good
Kooks LT Headers, Hi-flo Cats SLP Loudmouth II axle back, Ported intake & TB , K&N CAI. Tuned by Jeremy Formato.
07-08-2016, 08:09 AM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
It is an alignment issue. Take a read through this, print it and get a dead nuts balls on accurate alignment from a shop willing to read what your bring in and willing to take their time to do it right.
http://www.jpssonline.com/#/the-book...n-2010-camaro/ |
07-08-2016, 07:03 PM | #6 |
Probably a stupid question - would there be any reasonable recourse via warranty? I'm sure if I read the fine print such things aren't covered. It just stinks to get a CPO car with 4000 miles home, get car up in the air, and see the rear tire wear. Thanks guys.
07-09-2016, 11:30 AM | #7 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
I seriously doubt it. Even if it was new, most service departments wouldn't cover it.
07-11-2016, 05:11 PM | #8 |
its an alignment issue.
07-11-2016, 05:13 PM | #9 | |
07-11-2016, 05:17 PM | #10 |
Daily Driver 24/7 365
Drives: '15 CRT 2SS/RS/1LE Join Date: Jul 2015
Good luck!
I just hit 21000 miles on my stock 1LE tires. There is some road noise and a slight lack of traction compared to 10,000 miles, but the fun factor is still there in the corners too.
NPP Fuse Pull, Z28 CAI =
Previous Rides: 2005 Magnum R/T A5 CAI, Cat-Back 2014 RRM Camaro 1LT/RS A6/NPP CAI Follow Me On Instagram! |
07-11-2016, 06:57 PM | #11 |
Toe may be the culprit here.
07-12-2016, 10:00 AM | #12 |
Drives: Dark Knight Join Date: Sep 2012
I got 33k out of my stock 1LE tires. They didn't start looking like that until I hit the 20k+ mark
07-12-2016, 12:23 PM | #13 |
Drives: Race Car Join Date: Sep 2009
Alignment Issue!
07-14-2016, 01:36 PM | #14 |
Did you go get the alignment checked?
