11-29-2018, 04:24 PM | #1 |
Remote start not working
Bought a 2012 zl1, was told the remote start worked. Followed the directions, lock doors, hold for a couple of seconds, can hear a noise like it's trying to do something for a 3 or 4 seconds, but nothing happens. Any suggestions?
11-29-2018, 04:25 PM | #2 |
Instagram: Sangstah
Mine sometimes acts up, press lock twice and hold auto start.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
11-29-2018, 05:37 PM | #3 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
If you have a CEL the remote start won’t work. Just in case you have a CEL lol. And I also think it doesn’t work if the key fobs battery is dying. Not sure though
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
11-29-2018, 05:57 PM | #4 |
11-29-2018, 05:59 PM | #5 |
11-29-2018, 05:59 PM | #6 |
11-29-2018, 06:00 PM | #7 |
11-29-2018, 06:11 PM | #8 |
Instagram: Sangstah
Love mine, wouldn't have it any other way and love the old B&M t handle throwback look.
11-30-2018, 04:03 AM | #9 |
11-30-2018, 04:06 AM | #10 |
11-30-2018, 06:40 AM | #11 |
11-30-2018, 08:21 AM | #12 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
11-30-2018, 08:22 AM | #13 |
There's a list of things that will prevent it from starting. Yes the Service Suspension message means the car thinks something is wrong so it won't remote start.
11-30-2018, 03:50 PM | #14 | |
Drives: 2013 ZL1 Triple Black, 2015 2LT/RS Join Date: Apr 2012
My DIC display was reading "Service Stabilitrac", which is what you seem to be expecting. The input given to me was to disconnect the battery, wait a bit (I waited for about 20 minutes), reconnect and all should be good. The battery is very simple and quick to access. After I did this, all was perfect. The remote start function will not operate with a CEL showing. Try what I did and you should be fine. There was no objective reason for my DIC reading, if it helps with you situation. Best of luck. Let us know. |
