Old 06-06-2014, 09:48 AM   #1
Luismi
Drives: 2012 Camaro EU Transformers edition
275/40R20 and 295/35R20
Hi,
Has anyone run 275/40R20 fronts and 295/35R20 rears without any issue with stability control nor ABS?
Luismi is offline   Reply With Quote
Old 06-10-2014, 12:39 PM   #2
ss04flores
2012 Camaro SS
ss04flores's Avatar
Drives: 2012 camaro ss
Originally Posted by Luismi View Post
Hi,
I don't think that would be a problem but why would you want to have a smaller diameter tire on the back?
_________________________
2012 IMB CAMARO SS
ss04flores is offline   Reply With Quote
Old 06-11-2014, 05:58 AM   #3
Luismi
I'm running 315/35R20 right now and I feel like it's too much wide related to the front, although the grip is better with 275/40R20 rather than 245/45R20 I can feel a lot of understeer, and with the stock HorsePower of Camaro SS I thing is enough 295/35R20 for a good traction (275/40R20 definitely is not enough).
On the other side my rear wheels are 20x10.5 +25offset, very aggressive offset than makes the 315/35R20 Falken 453cc tires pass the fender about 1/2", that is not a problem because I've got fender flares, the problem is that with bumps and 4 people at high speed I can feel some rubbing with the fender flare. I want to make sure this won't happen again.
Old 06-11-2014, 11:05 AM   #4
ss04flores
2012 Camaro SS
ss04flores's Avatar
Try 295/40-20.
2012 IMB CAMARO SS
Old 06-11-2014, 11:06 AM   #5
ss04flores
2012 Camaro SS
ss04flores's Avatar
http://www.camaro5.com/forums/showthread.php?t=151912
2012 IMB CAMARO SS
Old 06-11-2014, 06:24 PM   #6
Luismi
Try 295/40-20.
But then the tyre would be closer to the fender, probably itīll be inside the fenders but if it isnīt then more rubbing.
Thanks in any case.
Old 06-12-2014, 09:33 AM   #7
golfaholic
golfaholic's Avatar
Drives: 2011 SS/RS Camaro
I run 275/40r20 up front and 295/35r20 out back, all Nitto Invos. I've had no issues with this setup. In hindsight I probably should have gone 315's out back since the Invos run a little narrow. I was worried about rubbing because my car is lowered but they would have been fine. Also, I was just reading another thread about a 275/305 setup using the MT street comps, which sounds like the perfect setup.
2011 SS/RS Camaro
Synergy Green Metallic
Aftermarket: Flowmaster Exhaust, Vararam CAI, PFADT Sport Suspension, Budnik "Ice" Wheels, Nitto Invo Tires
Upcoming Mods: Custom Grill and Badging
golfaholic is offline   Reply With Quote
Old 06-12-2014, 09:49 AM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I'd recommend a 285/35/20 front, and 295/35/20 rear.
shibbs is offline   Reply With Quote
Old 06-12-2014, 12:19 PM   #9
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
I currently run a 275/40/20 front and PSS 285/35/20 rear. I wish I'd gone with 285/35/20 front because I can definitely tell the difference in sidewall height and aesthetically, it's not the most pleasing.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 06-12-2014, 03:48 PM   #10
ss04flores
2012 Camaro SS
ss04flores's Avatar
Thanks in any case.
Well I would just change the wheels and get the correct offset. That would be my first concern. No problem. Glad i could help.
2012 IMB CAMARO SS
