06-12-2014, 10:01 PM | #1 |
Do I need centering rings ?
As the title says . I bought a set of used wheels and have a vibration at higher speeds . 22" savani wheels . The vibration is driving me nuts. The last owner says that they didn't vibrate on his camaro so I'm wondering if it could be the centering rings .
And I didn't have the vibration with the original wheels on so that rules out the car . Any help would be great , thanks
06-13-2014, 08:48 AM | #2 |
Car Enthusiast
Drives: 2010 Rally Yellow Camaro 2SS A/T Join Date: Dec 2010
yeah you would want to check to see if the rings are needed. Also some wheels when first cold are hard an will make you vibrate until they warm up
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016 |
06-13-2014, 10:44 AM | #3 |
corner barstool sitter
Check that the wheels aren't bent and that the wheels/tires are properly balanced.
Make sure that the Tinnermann nuts (those thin, flat assembly things) have been removed from the studs. Many (if not most) aftermarket wheels cannot accommodate leaving them on. Loosen and retorque the lug nuts in a true star pattern in several steps, and get the lug nuts somewhat tighter than just "snug" before lowering the wheel to the ground. Tighten them some more (in the star pattern) before putting the full weight of that corner of the car on that wheel for full tightening/torquing. Absolutely do not fully tighten each lug nut as you go through the star pattern just once. Norm |
06-13-2014, 12:04 PM | #4 |
It would definitely be the lack of hub rings that are causing those vibration, almost every time you buy aftermarket wheels you would need to get hub rings due to the difference in bore and hub size. So no worries, just get an inexpensive set, put them on your wheels and your good to go!
06-13-2014, 04:39 PM | #5 |
Thanks guys , I'll order the centering rings today . Hopefully that takes care of the vibration because they look great on the car.
06-13-2014, 04:45 PM | #6 | |
06-13-2014, 06:57 PM | #7 |
2012 Camaro SS
Drives: 2012 camaro ss Join Date: Jun 2012
Ive never heard of his. How did you come up with this theories?
_________________________
2012 IMB CAMARO SS |
06-13-2014, 09:24 PM | #8 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
I think he means the tires when cold are flat spotting. Once they warm up they smooth out.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
06-14-2014, 11:19 AM | #9 | |
Must be what he meant .
