02-16-2018, 07:07 PM | #1 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
Elite Catch Cans on SALE at Juiced Motorsports
The PCV (Positive Crankcase Ventilation) system is designed to regulate and remove fumes from the engine crankcase, and to alleviate crankcase pressure which could cause oil leaks or seal damage. The PCV system routes crankcase fumes into the intake manifold where they can be burned to eliminate harmful emissions into the atmosphere. The PCV valve controls the amount of crankcase flow volume depending on the engine's load. With large throttle openings (high engine loads), the more blow-by gases are produced, and the more the PCV system flows oil vapor in to the intake manifold. A small amount of that ignited mixture leaks past the piston rings and ends up in the crakcase. This leakage is often reffered to a "blow-by" or leakage past the pistons. Some of the oil mist and other products settle along the engine intake and over time form a "gunk". Our oil catch can collects the oil mist and condensed the fuel vapors while allowing "cleaner" gasses to pass back into the intake manifold. 2010-15 CAMARO CATCH CAN 2010-15 CATCH CAN W/CLEAN AIR SEPARATOR 2010-15 CAMARO E2 CATCH CAN 2010-15 CAMARO E2 CATCH CAN W/CLEAN AIR SEPARATOR |
03-04-2018, 08:25 PM | #2 |
Great prices with free shipping
03-17-2018, 12:57 PM | #3 |
Top seller. Keep that 3.6 clean
03-27-2018, 05:54 PM | #4 |
Keep your engine clean
04-12-2018, 09:39 PM | #5 |
Top quality catch cans at rock bottom pricing
04-23-2018, 03:30 PM | #6 |
04-23-2018, 07:41 PM | #7 |
Drives: 2010 2LT/RS Join Date: Mar 2015
What is the difference between all 4 of these Catch Can versions you have? I have an LLT and interested in getting one in the near future.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
05-05-2018, 09:47 PM | #8 |
Elite catch cans in stock and ready to rock
05-08-2018, 10:37 AM | #9 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Have an LFX with a dirty-side catch can already on, do you sell just the clean side and can you PM me pricing?
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-09-2018, 08:29 AM | #10 |
Drives: 2010 CAMARO 2SS/RS Join Date: Dec 2016
05-09-2018, 09:44 AM | #11 |
Drives: ZL1 Join Date: Mar 2018
05-23-2018, 03:46 PM | #12 |
PMs sent. Thanks guys
12-18-2018, 09:47 PM | #13 |
Top seller always on sale
01-17-2019, 07:07 PM | #14 |
Elite catch cans come with everything needed
camaro catch can, elite catch can |
