dave@hennessey
Old 01-16-2020, 03:48 PM   #1
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Car pushes left on hard acceleration
Hey all,
Car pushes left under hard acceleration if left unchecked... like middle lane to left lane if left unchecked going from 60-90.
Car has:
Pegasus Solid Cradle Bushings
Z-28 Rear Upper Outer Control Arm Bushings
BMR TR003 Adjustable Toe Rods
BMR Extreme Anti-Roll Bar
Carlyle LCA and TAs (from their 15" Conversion Kit)
Justice Pete's Aggressive Street alignment
Tire pressures equal side to side
Thanks
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 01-16-2020, 04:01 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
When did it start?
More to come.
Black_SS10 is offline   Reply With Quote
Old 01-16-2020, 04:12 PM   #3
PostNup
CAR-DASHIAN
After the Cam install
Old 01-17-2020, 10:01 AM   #4
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
Do you have aftermarket front wheels? With say a big change in tire width, or offset? If so, read about scrub radius. What it can cause during acceleration and deceleration when you change it. If not, the first place i would look is at the front radius arms.
Coleroad is offline   Reply With Quote
Old 01-17-2020, 10:53 AM   #5
PostNup
CAR-DASHIAN
THX. Stock front wheels and same tires. It does not do it on deceleration, that I have noticed.
I will put checking the radius arms on my list.
Old 01-17-2020, 06:47 PM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
So no problems before the cam install? Just a cam install?
Did you put in the cam?
More to come.
Old 01-30-2020, 02:53 AM   #7
rdanzel
Drives: 2010
That's pretty strange. Any update on this?
rdanzel is offline   Reply With Quote
Old 01-30-2020, 08:29 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Axle shaft possibly?
Orange Krush II
Old 01-30-2020, 10:24 PM   #9
'10CamaroDude
Drives: 2010 Camaro LS
Under hard acceleration, the thrust angle is changing, causing the rear wheel(s)
to steer the car. That is usually a radius arm; bad bushing(s). Could be LCAs, but
yours are new? IF they are adjustable, are both sides equal? If the cradle shifts
under hard acceleration, that also changes the thrust angle. Take the car in for an
alignment, they can correct the thrust angle if they know how. I think it happening
after the CAM install was a coincidence, or the torque shift exposed it.
'10CamaroDude is offline   Reply With Quote
Old 01-31-2020, 01:48 AM   #10
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man
Also make sure the rear springs are seated in the pockets. Had one slip to the side after jacking the car up and do the exact same thing.
ZL1C7 is offline   Reply With Quote
