08-14-2017, 02:12 PM | #1 |
Drives: 1969 Corvair, 2018 Camaro T4 RS Join Date: Mar 2009
Quad Tips on a 2018 Turbo Camaro
I ordered this Camaro with dealer install GFX, as GFX are not available for the turbo Camaro. After some study I realized installing quad tips involved more than lopping off the oem tips and clamping or welding on the new tips, so Friday found me at MRT Custom Exhaust, where they installed the v3 cat back and completed the fabrication needed to fit their quad tips to the lower cover.
As to what was involved I will quote MRT: The majority of the exhaust system is our production exhaust for the 4 cylinder 2016+ Camaro. The axle-back portion is custom and has been modified and adjusted to incorporate the quad exhaust tip design by MRT. Thank You Joshua Barth MRT Sales Manager Pictures in the following post. Laborsmith Last edited by laborsmith; 08-14-2017 at 02:29 PM. |
08-14-2017, 02:24 PM | #2 |
Pictures
08-14-2017, 02:45 PM | #3 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Hey, you traded your 16 turbo for an 18! Looking good!! Love the 1LE spoiler, so glad I put that on. Congrats, she's a beauty!!
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst |
08-14-2017, 03:48 PM | #4 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
So... MRT did a custom order for you? How much extra was it for them to do that? Can the general public order this set up? I would love to do a quad tip rear valance on my car. The only option for the 2.0 (besides a custom muffler shop) was the Mishimoto quad tip (not impressed with the sound)... needless to say, I'd much rather have the MRT exhaust.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
08-14-2017, 04:23 PM | #5 |
The parts pricing was the v3 plus the quad tips less a credit for the dual tips. Labor was five hours, and included some cutting, reshaping the axle back section, and welding.
The sound is awesome, deep and smooth, and I perceive no extraneous unwanted sounds. My thinking is a good muffler shop equipped with a mandrel pipe bender could handle the task. But it should be pointed out that MRT has experience doing this conversion, just not on a turbo Camaro. Until now, of course. Laborsmith |
08-15-2017, 08:32 AM | #6 |
YQ4 HD Cooling/Brake Pkg
Underside pic: it is raining now but when things dry out will try. I should give a shout out to BeckyD who tolerated a lot of ambivalence as to my choices, such as spoiler and GFX color (black or body color) as well as other LPO choices. Laborsmith |
08-15-2017, 08:48 AM | #7 |
To Start the Machine: Thinking over your question, I am not sure if MRT can mod the axle blind and the four hangers on mine had to be moved, but if they could do such that would facilitate installing. But the bright trim (surrounds the tips) housing would still need to be cut so the new quad assembly can be fitted. But it does slide back into place and one can not see anything to indicate any cutting in that area was done.
Laborsmith |
08-15-2017, 08:52 AM | #8 |
Drives: Camaro 2.0t, 300zx TT, LSTT Mustang Join Date: May 2016
Any sound clips on YouTube?
10-28-2017, 09:32 PM | #9 |
Drives: '17 1LT I4 Automatic Join Date: Aug 2017
What GM rear kit is that? It doesn't look like the stock GM#23404791.
I was really hoping there'd be an easy way to just get a new rear valence, and have a muffler shop cut the singles and weld on duals without having to get a whole new system. No such luck, apparently. Looks nice! |
10-28-2017, 09:35 PM | #10 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Nice......
10-31-2017, 12:11 PM | #11 |
i just got quad tips on my car. i also have a muffler delete.
i just got a new rear valance and picked out some quad tips. muffler shop cut off factory and welded on the quad. |
