dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Vendor and Seller review / feedback / experiences
Old 01-19-2014, 01:32 PM   #1
Rjizzle10
Drives: '13 Hot Wheels SS
Pros/cons buying pre modded car
So I'm looking to buy a new camaro but I want one with stuff already done to it, what are the benefits and disadvantages to buying a camaro that's already been modded.
Rjizzle10 is offline   Reply With Quote
Old 01-19-2014, 02:21 PM   #2
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
Disavantage: It will always be somebody elses Camaro.
myold88 is offline   Reply With Quote
Old 01-19-2014, 02:34 PM   #3
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
My biggest concern would be if the mods were done by someone who knew what they were doing. Bolt-ons maybe not so much but of any engine internal mods like a cam I would be cautious.
Retro69 is offline   Reply With Quote
Old 01-19-2014, 03:07 PM   #4
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
If you like what has been done to it, go for it. Bolt on's shouldn't be a problem, but as has been said, if there are internal mods, make damn sure you know what you are getting and who built it. If it's the owner or a shop you have never heard of, I'd real cautious unless you know there skills are good. If the car was built by a reputable shop, you'll be better off. In any case, I'd contact the builder and talk to them. If you do buy a modded car, be prepared, as anything that happens is now on you. I know of one person that bought a heavily modded car and 4 weeks later is having to put an engine in it. He was told there were absolutely no problems with the car.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 01-19-2014, 07:07 PM   #5
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
It's A lot cheaper to buy one already modded if that's what you want.
JLE58 is offline   Reply With Quote
Old 01-20-2014, 01:20 PM   #6
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
Cons: modded cars depending on who did them can be a ticking bomb
Pros: almost always you get .50 or .25 cents to the dollar they spent in mods.
I would go for a modded car, thats what i bought and im almost at 85,000 miles with no issues at all
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 01-20-2014, 01:30 PM   #7
Diode Dynamics
Diode Dynamics's Avatar
Drives: Camaro Lighting Experts
It really depends on the mods, but I'd say go for it.
As long as the current owner provides you with all of the needed information about the mods and the car's history.
Nick C.
John C.
Diode Dynamics
Follow Us: FB // IG // YT // TikTok
Diode Dynamics is offline   Reply With Quote
Old 01-21-2014, 11:16 PM   #8
Chain Blue Lightning
Chain Blue Lightning's Avatar
Drives: 2010 IBM Camaro SS
Pro: you don't have to spend cash on doing the mod yourself
Con: If you don't like the mod your spending money on something you don't like
Pro: If you don't like the mod you can remove it and replace with OEM. Then sell the parts to someone else!
Con: you won't get much for a used mod
Pro: The bad mods make the car less costly
Con: The good mods make it more costly
Pro: The mods may help when it comes time to resell the car
Con: The mods may not help when it comes time to resell the car
In the end it is either what you want or it isn't. My choice would be research it and test drive if your comfortable then buy it if it makes you nervous then look around more.
Good Luck
My Vehicles
1968 RS Camaro
1978 RS Camaro
1983 VH Commodore
1996 VS Commodore
2005 WL Statesman
2010 SS Camaro
Chain Blue Lightning is offline   Reply With Quote
Old 01-21-2014, 11:25 PM   #9
Tom13ss
Tom13ss's Avatar
Drives: 2013 Camaro SS 1LE
Pros...You don't have to spend the money on those mods now
Cons...The car was modded for a reason; to get beat on.
I personally like to buy stock, and if budget allows it I buy brand new!
This way I know what was done, when it was done, and who it was done by. Not to mention youll have all(if any) warranty info on the parts
Tom13ss is offline   Reply With Quote
Old 01-21-2014, 11:29 PM   #10
ford20
Drives: Boss 302
Con: You don't get to build your car and step back and go yeah I built it.
ford20 is offline   Reply With Quote
Old 01-23-2014, 09:03 AM   #11
PlainEnvelopes
PlainEnvelopes's Avatar
Drives: 2014 1LS BRM
That is a huge one in my opinion, I don't like to buy someone's project. I did it with my gti, but the previous owner was the top mechanic at my dad's shop. So I knew the car was built correctly and that he did not try and go cheap on parts. He did put a lot of the car back to stock when I got it so I got to play around with it a little. (Being in Cali he had to, to even come close to passing smog)
PlainEnvelopes is offline   Reply With Quote
