Vararam
Old 11-14-2013, 12:51 PM   #1
Twin2010
Drives: 2010 twin turbo ss
Just blew up my 2nd set of turbonetics turbos
First set had bearing material go through them and now after paying 1400 dollars to have them redone one is seized up and the other wobbles around inside the housing like something is broke. Less than 200 miles of driving and only got in the throttle hard a couple of times. I measured the flow of oil to the turbos and was told everything was correct after it was running. Any ideas wtf could be causing this? This is with a complete different motor than it happened with last time.
Twin2010 is offline   Reply With Quote
Old 11-14-2013, 01:12 PM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
ball bearing?
JLE58 is offline   Reply With Quote
Old 11-14-2013, 01:42 PM   #3
AGP Turbo
Drives: All things Turbocharged
Did you get any failure analysis done on the failed units? We can tell a lot by looking at a failed turbo.
#1-Boost leaks.
Low ZDDP oil.
BOV problem.
Contaminated oil. Where do the oil feed lines get oil from the motor in your kit?
AGP Turbo is offline   Reply With Quote
Old 11-14-2013, 01:55 PM   #4
Twin2010
It just happened last night so i dont know the details yet. I am getting the oil feed from behind the alternator bracket where the big allen plug was. I have checked everywhere for boost leaks and cant find anything. I would assume with a seized turbo theres an oil problem of some sort
Old 11-14-2013, 02:56 PM   #5
AGP Turbo
That is a non filtered source right off the pump, before the oil goes to the back of the block where the filter is. All the contaminants that would usually get caught in your filter, are being pumped right into the turbos.
Old 11-14-2013, 03:58 PM   #6
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
O.O ...that's where my YSI feed is too. What do you recommend?
K32 Camaro is offline   Reply With Quote
Old 11-14-2013, 04:00 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
a new builder?
Click to view my build thread
Old 11-14-2013, 04:06 PM   #8
Unreal
Drives: 2006 Z06
Blowers seem to be less sensitive than turbos to contaminates. They dump a bunch of oil over a set of large ball bearings. Turbos have small oil orifices and need clean oil for long life.
You can put a filter on the feed line, or take it from a filtered source.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 11-14-2013, 04:08 PM   #9
Mike@RMCR
Mike@RMCR's Avatar
Drives: Supercharged
The YSi has a filter built into the adapter on the supercharger.
Mike@RMCR is offline   Reply With Quote
Old 11-14-2013, 04:17 PM   #10
AGP Turbo
We use the filtered source where your oil pressure sensor goes on the back of your valley cover. And filter the oil again after the turbos but before the oil goes back into your motor. Clean oil is a good thing.
Old 11-15-2013, 08:45 AM   #11
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
That is where my oil supply is hooked up. I had to remove the intake to do it, but it was worth it to get a clean oil supply.
FrankT is offline   Reply With Quote
Old 11-15-2013, 10:15 AM   #12
AGP Turbo
Wise man. It's a very very minor investment of time.
Old 11-15-2013, 10:54 AM   #13
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Op, may I ask what size turbos you have and what cubic inches is the motor... Where are the turbos mounted...
I destroyed several. The first one was due to an improper oil orifice... When that turbo went, the other side went within minutes... Second set, ball bearing, lasted about a year and started rattling... Sent them in, upgraded, then grenaded two of those trying to make boost...as told to me by the manufacturer, we over accelerated/overspun them... We were way outside(to the right) of the boost map... 67 mm turbo in a 429 ci engine... Making 25 lbs of boost... High IATs etc... We knew we were hanging it out but went there anyway...now I have twin 76's...
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 11-15-2013, 10:55 AM   #14
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
This... Clean oil is an absolute must... I also change my Amsoil every 2000-2500 miles...
