Vararam
Old 03-14-2024, 04:05 PM   #1
jd10013
Drives: 2012 camaro
P0191
Hey everybody, haven't been here in awhile. anyhow, still have my 2012 camaro LS, about 130k miles on it now. been great car, never a problem........until now, lol. anyhow, I was on my way home today and while driving noticed a significant drop in power. when i looked at the dash the stabilitrack, CEL, and traction lights were all on, and the DIC said engine power reduced. I pulled over, turned it off, stated it back up, same thing. repeated again. I was about 4 miles from home, so I drove it. when I got home I plugged in my code reader and got P0191, fuel rail pressure sensor "A" circuit range/performance.
now the weird part. I went to my car to check it again, been off maybe 5 minutes, and when I started it up there was no longer any lights but the CEL. the DIC was back to showing the speed too. i took it for a quick spin around the block, drove like normal.
so, any thoughts, ideas? was it an arbitration? something temporary? safe to drive?
jd10013 is offline   Reply With Quote
Old 03-14-2024, 04:13 PM   #2
gtstorey
Probably a temporary problem that reset itself but needs a certain amount of drive cycles to reset the CEL. Unless you cleared the code when you read it.
It may come back as an issue or clear up and never set again.
Old 03-14-2024, 04:19 PM   #3
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Because it seems to be an intermittent issue at this time I would put a fuel rail pressure sensor in it and clear the code. I see a lot of FRP sensors go bad so I would start there. GL
Mouse330 is offline   Reply With Quote
Old 03-14-2024, 05:01 PM   #4
jd10013
Drives: 2012 camaro
yea, i left the code in there for now, Im assuming thats why the CEL is still on.
