04-30-2021, 09:09 AM | #1 |
Drives: 2012 Camaro 1LS Join Date: Apr 2021
LFX engine gas octane
I have had a 2012 v6 camaro for the past year and have been putting 93 in it. The reason being is that the original owner money shifted the original engine and replaced it with another lfx engine. He told me to put 93 in it but I see no reason to do so. Would putting basic 87 cause any problems? I have put 87 in it once and didn't notice and difference in performance or sound but I just don't want to cause any damage.
04-30-2021, 09:24 AM | #2 |
it requires 87 octane no need to run more than 87. Even the SS's have a low octane table set up so it will run on 87. Top tier fuel is recommended though, has detergents to help keep from carbon buildup.
04-30-2021, 09:58 AM | #3 |
i have used 87 and 89 in my LFX,and there is no real difference.i just have a hard time putting lawn mower gas into my car so i prefer the 89.only reason you would need 93 is if the car had been custom tuned to run on higher octane.
04-30-2021, 10:26 AM | #4 |
Running Higher octane than is required is actually detrimental to an engine. Higher octane resists combustion. When the tuning is set up to run 87, running higher octane will lead to a less complete burn and more carbon deposits and actually less power.
04-30-2021, 10:49 AM | #5 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
There's tons of threads and topics on this and you will get both sides of the spectrum on this.
When I owned my v6 and data-logged, the low octane tables were awful. They pulled so much timing and used knock sensors like crazy. The car ran much better on 93 octane. Eventhough this is "just a v6" it's also a high-compression, direct-injected, DOHC engine with a lot of sophistication. The LS3/L99 is old technology, so you can't really use the v6 vs v8 debate on these two engines in my opinion. I recommend high octane for the v6.
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
04-30-2021, 12:55 PM | #6 |
I do believe the car was tuned before I had it. Is there any way to find out without going to a tuner?
04-30-2021, 01:31 PM | #7 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
I ran 93 in mine for a few months and didn’t see any performance or fuel economy differences although I also know others have had different results. I just run 87 nowadays.
04-30-2021, 02:21 PM | #8 |
mines bone stock,but some of the other people here might know how to tell...i see you also live in hot and humid florida,thats one reason i like to use 89 instead of 87 octane.
04-30-2021, 02:56 PM | #9 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
dead horse
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
04-30-2021, 05:59 PM | #10 |
but...what do you feed a dead horse?
04-30-2021, 07:35 PM | #11 |
mine gets premium 93 feed
05-01-2021, 02:04 AM | #12 |
Drives: 2010 LS Join Date: Feb 2021
Run the higher octane when ambient temperatures are above 60 degrees.
If you feel the timing being pulled in hot weather, use higher octane. I can tell when the timing is being backed off. When I change to higher octane, that doesn't happen. I can feel the timing pulls in 2nd gear. Winter, I run 87 or 88, but when the summer comes around, you need the higher octane level to prevent timing pulls. Believe it or don't, but I can tell the difference. I know how to make my engine knock and ping while going up a hill, in "M" 5th. There is a specific hill I run up, and press the pedal almost all the way to the floor, and when it hits a certain point I can hear the clattering. When I run with 91 or higher octane, it doesn't happen. Running higher octane also increases fuel mileage, from 15 gallons to 14.5, and with the intake now ~13.5 per 380 miles. I run the same 380 miles 3-4 days a week, so I test all the fuels, in all the temperatures, so I got it down pat. I fill the tank with 88 till the pump shuts off, then I squeeze 2 more gallons of E85 on top if it. Did the round trip back to the same gas station, it took ~13.5 gallons. |
05-01-2021, 02:24 AM | #13 |
Drives: 15SS Camaro Join Date: Dec 2020
My v6 runs terrible on 87 but of course it does because it has a premium gas tune in it. Like Chibi mentions up above the low octane tables are horrible. If I put regular gas in the car runs so bad you never put it in again.
My Subaru calls for regular but there are times I can hear it pinging and pulling timing. you can feel the reduced power. The Camaro on the other hand just flat out won't go it pulls that much timing on 87. |
05-01-2021, 02:25 PM | #14 | |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Motors around 11.5:1 compression and detonation is the enemy. Will it run on 87? Sure. It would run on retreads and dino oil too. Never saw the point of being cheap on fuel, oil or filters myself.
