09-14-2015, 04:41 PM | #1065 | |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Not spraying that much right now, just enough to get the supercharger cool during the burnout. The Vortech V3 is a self-contained unit with its own oil for lubrication. I also use 50/50 so it is not as corrosive. It also keeps the supercharger more efficient and allows more boost, I run about 0.8 PSI more just spraying a 175 cc/min. Spraying too much will cause it to be slower but the key is to find the right amount. A 225 cc/min slows me down 3/10th in 3rd gear, and none is 2/10ths slower. |
09-14-2015, 05:10 PM | #1066 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I'll be there watching though...
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
09-14-2015, 06:41 PM | #1067 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Bravo, MFGB. The dedication pays off!
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
09-17-2015, 10:27 AM | #1068 |
I drove the Camaro for the first time yesterday since the track, still fast with that last tune. I miss the prepped track and drag radials, my regular tires have zero grip and put on a nice smoke show.
Been trying to figure out what my HP number is now. The TC I website says 497 with 4055 lb and 116.27 trap. Don't know if this is flywheel or rear wheel. With a 20% drivetrain loss it's 622 flywheel. 553 for 10% loss, 585 for 15%. Locking converter with one piece driveshaft should help the loss. This site also does it based on ET and weight, says 487 for the 11.840 et. http://www.ajdesigner.com/fl_horsepo...apsed_time.php |
09-17-2015, 12:45 PM | #1069 |
I had to play with that calculator.. I don't know how accurate it is but I put my stock info in and it came up with exactly what my car dynoed at stock.
Stock: 3900lbs + 95mph = 261hp Present: 3865lbs + 119.88mph = 519hp Sounds good I'll go with that lol.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph Last edited by JantzenOKC; 09-17-2015 at 10:07 PM. |
09-17-2015, 01:05 PM | #1070 |
So it is rwhp, not flywheel. Also, I can't believe my car is 200 lbs heavier than yours, need to lighten her up next time. According to the TCI page, I would run 11.45 @ 118 at your weight.
http://www.tciauto.com/tc/racing-calculators/ |
09-17-2015, 04:34 PM | #1071 | |
I need to get my car in the 11s too so OKC can have the fastest V6 Camaros in the country. V6 Outlaws!
09-18-2015, 09:55 AM | #1072 | |
Would be nice to have the fastest V6's at the track, too many slow V8 Camaro's there so we need to pick up their slack. |
09-19-2015, 06:21 PM | #1073 |
HP Tuners has a program called RaceRender, lets you overlay data from the scanner onto a video like GoPro. Tested this out with my 11.84 video. The middle gauge is the boost.
09-19-2015, 11:34 PM | #1074 |
Boosted
Drives: 2012 1LT RS... with snails Join Date: May 2012
That's a pretty cool video!
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani* |
09-25-2015, 09:12 AM | #1075 |
Looks like I'm not done tuning yet, modified the cams more and gained more time in 3rd gear. Might only translate to 0.1-0.2 off my ET but it will increase my trapspeed. Down low it doesn't look like the cams give any significant increase, but it might be because the gears are to fast.
What I'm doing is getting the intake valve to open just before the pistons hits TDC between the exhaust and intake stroke. My exhaust valve is still open so the intake charge is cleaning out the chamber and cooling down parts as well. This wouldn't work on a Turbo car since the cool air would slow the turbine down. It worked last time at the track, now I'm trying to squeeze more on the intake side. |
09-25-2015, 12:02 PM | #1076 |
So does that mean you'll be out there tonight in the Camaro?
09-25-2015, 12:26 PM | #1077 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-25-2015, 01:09 PM | #1078 | |
I'll be out there but in my Mustang. The Mustang Club will be out there and want to show them how it is done. I also will be working on its tune, hard to do pulls on the street with its 3.15 gears. That thing gets over the speed limit real fast.
I added quite a bit of timing down low along with getting the intake cam to close about 3 degrees after BDC. He might have retarded it to help with drivability. I would add timing until your knock sensors see something or you don't gain anything. Also see about disabling Tip-In management, don't have my computer with me so can't see if the LFX has it. Usually high octane is only needed for high RPM usage. |
