07-23-2015, 07:16 PM | #1023 | |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
I drive mine everyday. If I recall correctly. you had problems because of your BBK intake. I think the vendor even addressed your problems in a thread. I don't know why you always bring it up, because your other mods were responsible. They were incompatible with the VTC.... VTC even told you as much. Yet somehow, you always leave that out of your posts about the VTC.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
07-23-2015, 07:20 PM | #1024 | |
Sent from my SM-N900V using Tapatalk
-Cameron Lashley
Albany, GA 2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992 . |
07-23-2015, 07:26 PM | #1025 | |
I'm not sure. I think it's mostly aftermarket throttle bodies. I know with Krisprz, it was his BBK 102mm throttle body. He also had problems because he hadn't connected the throttle sensor wiring properly (to the throttle body). The vendor bent over backwards to help him and even ended up responding publicly in a post. He always seems to forget those details. You can't expect Vitesse to test the product compatibility with every mod on the market. Some people have had legit problems with the product causing CELs. Most haven't. From what I've seen, if you are one of the unlucky ones, you just remove the VTC and get a refund. No damage is done. 95% of people who install it never have any issues.
07-23-2015, 07:29 PM | #1026 | |
-Cameron Lashley
07-23-2015, 07:37 PM | #1027 |
If I were you, I'd email VTC and ask if there are any issues using the vmax and VTC together. To be honest, I think that once you get the VTC, you won't want the vmax anymore. Throttle response with the VTC is insane.
07-23-2015, 07:39 PM | #1028 | |
-Cameron Lashley
07-23-2015, 07:43 PM | #1029 |
Can't wait to see your response once you install it. The install is pretty simple, but calibrating it is aggravating. I think it took me about a dozen attempts to get it properly calibrated. It's a pain in the rear. That could also be why some people have probs.
07-23-2015, 07:48 PM | #1030 | |
-Cameron Lashley
07-23-2015, 09:17 PM | #1031 | |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Ok first off, I'm just saying my experience with the vtc. Did I say it was bad? No. Did I say not to get it? No. And go back and look at my thread I said I THOUGHT it was my throttle body. The vendor assumed that it's incompatible and maybe or maybe it isn't. He would not know unless he actually had my car with him to see. Vtc is an amazing product, but just not for me I guess. And also you know what else I left out in my original post? After pushing in the throttle body cable in the throttle body and heard the click the next day I connected the vtc back and recalibrated it correctly(I am sure 100%) and everything was fine, but later when I was going back home I got a reduced power mode and cel again. Hmm what else do you have to say now? I didn't say anything cus I was already set in sending it back which I did and they have great customer service. For some reason you are still in denial that just because people have problems with the product you have it won't happen to you. And maybe it won't, but I am telling my experience with it and I'm not saying don't get it. To each their own.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez Last edited by krisprz2010camaross; 07-24-2015 at 01:23 PM. |
07-23-2015, 09:25 PM | #1032 | |
Bbk intake wtf??
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
07-24-2015, 05:41 AM | #1033 |
If you haven't had any problems with your VTC, great it is a fantastic mod WHEN IT WORKS . Hell, you may never have problems with it. If you get problems with your VTC don't be at all surprised (takes about 6-7 months). If an opinion is expressed here questioning the quality of the VTC,or the issues they have had with it, no one needs to get all butt hurt if they disagree.
07-24-2015, 09:48 AM | #1034 | |
Drives: 2014 2LT RS Join Date: Apr 2015
repairs/replacements have been made to show some are the issue. others have issues that go away after repair/replacement. Yet the vast majority have not reported any issues suggesting the device is mostly not an issue, just a smaller amount are an issue or cause an issue. as long as Vitesse continues to replace with success it is a great mod. |
07-24-2015, 01:49 PM | #1035 |
It is a great mod unless you get the "reduced power " on the interstate
07-24-2015, 02:01 PM | #1036 |
