Old 05-31-2016, 09:44 AM   #1
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Foggy headlights !? 😡
So I thought I had an issue with the INSIDE of the headlight....
I went to Auto zone to buy a DIY kit to clean the headlights since theyre fogged up.
Turns out its an issue on the inside of the light itself.
So has anyone had this issue ? Do I have to replace the en tire headlights themselves ?
Dmpsix is offline   Reply With Quote
Old 05-31-2016, 01:00 PM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Your post doesn't make sense...
I thought it was the inside of the light, but it turned out to be the inside of the light!
If you have fog/condensation on the inside of the headlamp lens then the assembly is not sealed and either needs to be replaced, or resealed (most people just replace)
It's also possible the little seals where the bulbs go in are not closed properly, but less likely if you haven't messed with them
TommyTheCat is offline   Reply With Quote
Old 05-31-2016, 01:24 PM   #3
Dmpsix
Dmpsix's Avatar
Stupid auto correct sorry
But the issue is on the INSIDE instead of the OUTSIDE lol...
But they're two circle right where the bulb is, it looks like the bulb burned the inside of the headlight plastic
I'll post pics shortly
But replacing them is what I gotta do though right ? Because the fog shows up at night all blurry and ugly /:
Old 05-31-2016, 02:22 PM   #4
Dizzy82
Dizzy82's Avatar
Halogen or H.I.D. bulbs?
Old 05-31-2016, 02:57 PM   #5
camaro2ss/rs
Drives: 2ss/rs
H.I.D. bulbs on the camaro will do what you are talking about over time.... never seen a camaro not have it
camaro2ss/rs is offline   Reply With Quote
Old 05-31-2016, 04:11 PM   #6
Dmpsix
Dmpsix's Avatar
Are you serious !? Damn
How the hell do some people keep them looking brand new? Not use the damn car!? lol
Old 06-01-2016, 08:44 AM   #7
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
I had a guy here bake my headlights apart and then clean the inside of the headlight lens, look as good as new. It just wiped away.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 06-01-2016, 10:11 AM   #8
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Somewhat normal on most vehicles, just condensation that will evaporate,
see the Tech Link.
http://sandyblogs.com/techlink/?p=3195
MMC is offline   Reply With Quote
