Old 04-26-2016, 08:32 AM   #1
Blazin383
Blazin383's Avatar
Drives: 2016 SS
Direct Injection and Slow Starting
My 2SS seems to need three or four turns before it fires, whereas my 2012 Vette always fired on the first roll. I thought I heard somewhere it was because of the direct injection, but I did a search and couldn't find any discussion on this.
Is it typical? Is it because of the direct injection, and if so, what is it about direct injection that causes it?
Blazin383 is offline   Reply With Quote
Old 04-26-2016, 08:38 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
#6 on my list- and I tell you why.....
http://www.camaro6.com/forums/showth...=things+normal
Old 04-26-2016, 08:41 AM   #3
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
I couldn't answer why, but it appears that most if not all of us are experiencing the same thing. I don't think it's an issue or fault at all, just an idiosyncrasy of the engine in our Camaros. The first time I started it after sitting over night, it worried me, but now it's become the norm and it's ok. It seems as though the engine doesn't get an initial dose of fuel for just a second or two?????
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 04-26-2016, 08:42 AM   #4
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Not happening with ours, but we do live in a warm climate.
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
jdasnt3 is offline   Reply With Quote
Old 04-26-2016, 08:44 AM   #5
Iroc_Z28
Iroc_Z28's Avatar
Drives: 2017 1SS 1LE
Direct Injection engines may have slightly longer cold crank times than that of port fuel injected engines. Direct Injection systems run at higher pressures and the mechanical pump on the engine (driven off the cam) must build up the required pressure before the first injection event occurs (DI runs required around 2000+ psi fuel pressure compared to 40-60 psi for port injection).
Following are typical DI engine crank times using gasoline:
If the temperature is below -22°F (-30°C), the recommendation is to perform an assisted start (such as with the use of a block heater).
Iroc_Z28 is offline   Reply With Quote
Old 04-26-2016, 08:46 AM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Old 04-26-2016, 09:22 AM   #7
andrec10
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6
Makes sense now. 2000 PSI is nothing to sneeze at!
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package.
Ordered 1-28-16: 1100
2-11-2016 :2000
2-15-2016: 3000 TPW of 3/7...That went quick!
2-26-2016: 3400 Status TPW 3/7
3-5-2016 : 3800
3-8-2016 : 4300
3-11-2016 : 4B00
3-15-2016 : 4200
3-22-2016 : 4800
3-29-2016 : 6000!
andrec10 is offline   Reply With Quote
Old 04-26-2016, 09:40 AM   #8
HCGxKaLiBeR
HCGxKaLiBeR's Avatar
Drives: 2018 Audi S4/2016 Carmaro 2SS
Interesting. My bimmer would start to prime the injectors/pumps after I unlocked the door.
I have not get my 2ss yet. I can't test it. But I think if you unlocked the door and let it sit for 5-10 seconds before you hit the Start Engine button. Maybe it will improve the crank time.
HCGxKaLiBeR is offline   Reply With Quote
Old 04-26-2016, 09:45 AM   #9
JonGSA
JonGSA's Avatar
Drives: 2016 2SS Hyper Blue
^ My A4 did the same thing. Same direct injection HPFP setup. Everytime I opened the drivers door, I could hear the fuel pump prime up. No matter how cold or warm it was, it always started in under a second with 2-3 cranks tops. But then again, it was a smaller 4 cylinder. Not a 6.2l beast that has larger rails and pump to prime up before ignition.
'16 2SS Hyper Blue Metallic - M6 - NPP - MRC -Black bowties - CAI Intake - SW Cat Back w/NPP
Other money pits:
'13 S1000RR
'11 R1200 GS Adventure
'01 HD Sporty 1250
JonGSA is offline   Reply With Quote
Old 04-26-2016, 09:59 AM   #10
Mr. Wyndham
Priming is different than pressurizing, I imagine, though I'm not a direct-injection engineer.
This car has an electric fuel pump in the tank to pressurize the feed lines and probably prime the main pump. Then the main pump is driven off of the camshaft with a three-lobe cam which produces the high pressures for the system.
Old 04-26-2016, 10:10 AM   #11
enzia35
Drives: '16 Garnet Red 1SS
It definitely seems pretty cool. I watched the Aston Martin Vulcan start up video, and that thing primed for a longgg time. So I figure it's a race car type thing, haha.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 04-26-2016, 10:19 AM   #12
L&M CAMARO 6
L&M CAMARO 6's Avatar
Drives: Just a fan for now
Never had that problem with my DI engines. Must be a gm thing.
L&M CAMARO 6 is offline   Reply With Quote
Old 04-26-2016, 10:30 AM   #13
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
The colder the temperature the slower the crank the longer time it takes to develop the required pressure.
MMC is offline   Reply With Quote
Old 04-26-2016, 10:41 AM   #14
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
My 3.6L DI engine ('09 Outlook) does not crank long before starting, even in freezing temperatures. I wonder why the system on the LT1 takes so much longer for a seemingly similar setup. Is there a reason the LT1 would take longer to build pressure than the 3.6?
