03-19-2016, 09:01 AM | #1 |
Drives: 2015 Red Rock ZL1 Join Date: Dec 2014
Battery Tender
Quick question, does a battery tender have to hook straight to the battery or can it hook to the + port and - terminal under the hood?
Alex
2015 Red Rock ZL1 Panama City Beach, FL |
03-19-2016, 09:32 AM | #2 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Under hood is fine.
03-19-2016, 09:33 AM | #3 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I hook mine up to the front and have never had a problem and it works fine.
03-19-2016, 09:34 AM | #4 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I have a tender but I hooked straight to the battery. Other members have posted, and say you can hook them up under the hood it and works just fine. You'll still be sending a charge to the battery so you should be fine. Maybe some who has actually gone this route will chime in.
03-19-2016, 09:50 AM | #5 |
Drives: 2014 ZL1 6M Join Date: Aug 2015
Hmmm...the tender I had for my 911 TT just simply plugged into the accessory
power outlet inside the cabin...then you would just carefully shut the door on the wire (made sure it was loose each time) and then plugged the tender into the wall??? Maybe the one for Camaro works different???
2014 ZL1, 6M, Summit White/Black, Carbon Fiber hood insert
2014 2SS/RS LS3 "sold" ZL1 Exclusive Member |
03-19-2016, 10:11 AM | #6 | |
-Cameron Lashley
Albany, GA 2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992 . |
03-19-2016, 10:22 AM | #7 | |
Drives: black and silver Join Date: Apr 2014
03-19-2016, 10:24 AM | #8 |
The ports are electrically the same as the battery posts
03-19-2016, 01:18 PM | #9 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Hook it to the red cap port, and ground it and your good to go.
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
03-20-2016, 11:19 AM | #10 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I hooked mine up to the battery directly. Ran the hook up line under the edge of the trunk liner and it is just inside the trunk lip. I pop the trunk, attach the lead, and put the trunk lid down, not latched, for charging. So in your case you would pop the hood, to access the terminals in engine compartment. I chose to pop the trunk, to go directly to the battery.
03-20-2016, 11:39 AM | #11 | |
Camaro: A Legend Reborn!!
I did the same as above. As for a charger I use a Sears Diehard charger, and have had no problems so far. I paid 35$ on sale. http://www.sears.com/diehard-platinu...Q&gclsrc=aw.ds
[SIGPIC][/SIGPIC] |
03-20-2016, 11:59 AM | #12 |
i hooked up the loops that came with the battery tender so all i have to do is plug it in... its way better then using the clips
03-20-2016, 12:03 PM | #13 | |
'It's an experiment'
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
03-20-2016, 12:08 PM | #14 |
