Vararam
Old 12-17-2013, 10:16 PM   #1
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
OD Cog questions
I am thinking about having an OD Cog installed but I have a few questions. I understand the whole 1:1 ratio Cog but what would be the next step up in size and where will it put my boost at on my Magna? I've been told the next size up would be approx. 25% increase in boost. Seeing is how I'm somewhere around 7 psi on stock Magna setup (can someone confirm this) isn't that going to put me at almost 9 psi? With that being said I have read that 10 psi is a bit high for a stock Cam on 93 pump gas. I always like to stay safe and conservative as this is my DD. Is it recommended to add a smaller pulley up front when running off a stock bottom and cam? If so what pulley should I go with up front? Or, will I be fine with just the rear OD Cog plus the ID850's, ZL1 fuel pump, ADM fuel controller, 2" headers and CAI I will also be having installed at the same time? Thanks for the help guys and gals.
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 12-17-2013, 11:44 PM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Would more than likely be closer to 11 psi.
JLE58 is offline   Reply With Quote
Old 12-17-2013, 11:48 PM   #3
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
I would go with the OD and if you are concerned about too much boost, pulley off the front to drop boost
jrpxxii is offline   Reply With Quote
Old 12-17-2013, 11:53 PM   #4
jrpxxii
jrpxxii's Avatar
Your going to lose 1-2psi with headers as well
Old 12-17-2013, 11:59 PM   #5
jvoisel
Drives: 2010 2SS/RS M6
Maggie on stock 3.8 pulley I made 7.6 psi
Added headers and it dropped to 7.0 psi
Added OD cogs and I make around 11psi depending on weather.
I have the blower with stock 3.8 front pulley, OD cog rear, headers, and an adm cai. The day we dynod it, it was around 75deg and made 550/565 and peaked right around 10.7psi. The other night it was around 35deg and I saw 11.3 psi, letting off at ~5700.
I'm running stock internals(only mods listed above) on pump gas with Siemens deka 63# injectors, zl1 pump, and adm FPCM getting plenty of fuel
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 12-18-2013, 12:31 AM   #6
MS7
MS7's Avatar
Drives: 2011 camaro LS3 supercharger
in my opinion
save $ & get 3.6 it will add 1 or 2 of boost.
i installed the (OD). my boost jump from 6 to almost 11 and cost me alot of troubles.after that installed front pulley 4.1 to drop my boost to 7
SLP TVS 2300,LS9 cam,ZL1 fuel bump, ADM FPCM,850ID,LT headers,CAI intake K&N, X pipe with stock exhaust Eibach 1inch suspension,Mantic Clutch 700HP, 91fule .8psi METH AEM, no timing up 557 RWHP
ZL1 black wheels,ZL1 front bumper, ground effects,
MS7 is offline   Reply With Quote
Old 12-18-2013, 12:43 AM   #7
JHall651
JHall651's Avatar
OD Cog questions
Wow. See that is my concern. I really don't want to go higher than 9 maybe 10 psi at the very very max. Everything I have seen on here people running straight rear OD Cog are pushing 11. Kind of turning me off the idea of OD Cog. Only thing I'm concerned with playing with front pulleys is belt slippage. If I go with the front 3.6 pulley do I have to get different belt and better tensioner?
Old 12-18-2013, 09:33 AM   #8
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
You have the fuel mods, headers and CAI. Go with the OD rear cog. If you have too much boost go a little bigger on the front pulley.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 12-18-2013, 11:33 AM   #9
H-E
Drives: 2010 zr1 Camaro 2011 vert
If I was spending the money on cogs I would do the od and go with a bigger front pulley for belt wrap.
H-E is offline   Reply With Quote
